Question about Campbell Hausfeld Welding Tools
I had to put a new switch on the front of my 90a Campbell Hausfield wire welder. This is a three pronged on and on switch that is either high or low . One prong is 15a the other prong is 20a and the third is a ground. The problem is that the prongs on the old and new switch are labeled 1, 2, & 3 and I have no idea which one is high, which one is low and which one is the ground. When i got the welder someone had already dismantled that part of it. I also don't know which colored wire of the three is ground, 15a and 20a.
  • 1 more comment
  • David Hill Mar 12, 2011
    -I just need a wiring diagram for the hi-lo switch I just bought for a Farmhand Autostrike 85 welder made by Campbell Hausfield. It didn't have a switch for the 15a-20a hi/lo switch when I got it. So I don't know which wire is high,lo,or the ground. I also don't know which one of the three prongs on my new switch is high, lo, or ground.
    It is a Farmhand welder marketed by Tractor Supply, but made by Campbell Hausefield. It is an "Autostrike" 85. The closest thing to a model# I can find is DK688519AV. There is no model # on the back of the welder. It has a on-on rocker switch on the front that I had to replace, but I don't know the wiring of the three prongs I don't know which wire is hi, lo, or ground, and I don't know which prong of the 123 listing is hi lo or ground.
  • David Hill Mar 14, 2011
    Still not enough detail to really be helpful, but it was the best answer I got. I still need more detail in layman's terms and not so much "electrician" shop talk that I don't understand, and a wiring diagram.
  • 12,061 Answers
OK well usually whenever a switch such as this is utilized, usually the Center Connector is the "Feed/Fed " and the two "Outer" terminals are the "Outputs/Inputs", However this is NOT the way your switch is wired, it seems yours is more of a "Selector" switch, IE: Low to High.
What you first need to do, is use an Ohm meter, and find the Earth wire, (usually this wire is green, or green/yellow, sometimes even Black) but CHECK this, in any event, this wire is most likely the "Common" and the 15a & 20a are connected to that in turn? and when switched it selects a High speed or a Low speed, by the putting of a Ground signal on either one of those connections?
You also need to meter out the switch to find that common connection, and which one is active at default, and then use i would think, the LOW setting as default, with the High, being the selectable.
hope this helps, BE CAREFUL PLEASE.
I have searched for data on this but could find none, perhaps you could try the manufacturer, i have no doubt, they will assist you if you require.
Posted on Mar 12, 2011
110 volt welder the wire stays energized even when the feeder stops and your off the trigger. Campbell Hausfeld flux 80. Any ideas?
That could be 2 things. Either the switch in feed assembly is bad or the relay inside the unit is sticking.
Nov 16, 2015 | Campbell Hausfeld Welding Tools
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfield wire welder feeds after trigger release!
has it done this before some wire feed welders the cheaper ones have hot switches mean that push wire all the time stuped i know but if it is not a hot switch than it is making contact some how and it could be inside the wip check it as best you can or take the wip in to where you got it from
Nov 10, 2009 | Cars & Trucks
Wont come on when switch is pushed to on
looked up Campbell Hausfield service on internet. found dealer within 1 mile of home.
Sep 11, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
My welder wont work
this is a very cheap welder ,so dont hope for a lot out of this welder.any who this is called a feeder hose.and you'll have to practice running the wire th ru this feeder hose to straighten the wire out till the wire goes th ru the hose do not have the wire going th ru the machine that the clamp is tightened tighten after the wire is through.and then the wire should only be tight enough to push the wire through ,thats something you ll have to play with to get it right.hope this helps .jojogunne
Mar 14, 2009 | Campbell Hausfeld Welding Tools
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Welding Tools Logo
181 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
