Question about Dryers
Problem With Maytag Dryer(PYE2300AYW)
The dryer does not start at all. I have verified that the following all work: there is good 240V power to the unit; the on/off switch /timer unit replaced with a new one--dryer still does not go on; the switch on the door tests OK. Thought it might be the thermal switch near the motor? PLEASE help...my 4 year old twins need dry clothes! Thank You, Bill
You check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Posted on Aug 01, 2008
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
PYE2300AYW dryer doesn't heat up, but vent system ...
May 20, 2010 | Maytag PYE2300AY Electric Dryer
My dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
I have a maytag performa electric dryer that's giving out no heat. model# pye2300ayw. what do I do?
could be three things. 1st) 240v should enter the unit. if 120v is missing then the unit will run but will not heat (on an electric dryer).
2nd) the thermal cut-off is not showing continuity and therefore not allowing voltage to travel to the element. 3rd) could be the element itself not showing continuity.
Jul 14, 2009 | Dryers
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
263 people viewed this question
Top Dryers Experts
