Question about Sunbeam Microwave Ovens
My electrical water kettle does not heat water...how to solve the problem?
    Guru:
  • 479 Answers
Check the kettle at another socket to ensure the socket isn't the problem.
Replace the fuse in the plug.
If the power flex is removable from the kettle, check the terminals in the connector havn't become burned.
The chances are that the element may have burned out in the kettle and in this case it probably isn't worth repairing.
Posted on Mar 12, 2011
How to get full power from outlet???
If you are getting your microwave to turn on then you are just fine on your outlets. They should be putting out 120v. You just have an under powered Microwave.
Dec 14, 2015 | Microwave Ovens
My dualt kettle leeks water from its base is this dangerous to keep on using
Yes, it is dangerous. Water is a good conductor of electricity. You or other members in the household might get electrocuted!
Better to be safe than sorry.
May 15, 2011 | Microwave Ovens
I turned on the cordless electric kettle without water! the metal rod inside the kettle turned black? was it burnt? i tried boiling water again and it worked. but is the metal rod toxic or not? can i still...
Yes, if your worried, use a fine emory paper to clean off the tarnish from the heat scorch. You may have shortened the life a little on the element but it is fine as long as it is not spalling, of flaking.
Mar 24, 2011 | Microwave Ovens
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
How do you desalazize kettle?
If by desalazize you mean remove the deposits which build up from the minerals in your tap water, the easiest way to do it is with white vinegar (most vinegar will work but white is best for cleaning).
  1. Fill kettle with a mixture of white vinegar and water (about 50/50 but it doesn't have to be exact) until it covers as much of the deposits as possible.
  2. Heat the kettle until the liquid boils
  3. Let the kettle sit with the liquid in it for 3-6 hours
  4. Empty and Rinse
  5. Fill kettle with regular water, boil, and empty to get rid of any lingering vinegar taste.
If the deposits are especially thick, you may need to repeat steps 1-4 before moving on to step 5.
Mar 01, 2011 | Microwave Ovens
What does it mean when it is descaleing?
Kettles and indeed any appliance that heats water gets a chalk "scale£" on the element. To remove this use spirit vinegar, that will dissolve the chalk. Wash thoroughly afterwards.
Dec 20, 2010 | Microwave Ovens
I bought a Bellini electric cordless kettle about three months ago from Target and now the lid won't shut, hence the kettle won't stop from boiling. What do I do - is there any guarantee?
i brought a belline kettle from target 2 months ago and now the lid wont shut where would i find a contact no for the company as target wont issue me a new one and i dont have my reciept after all who would have thought it would be faulty after 2 months
Aug 09, 2010 | Microwave Ovens
Keurig makes loud noise and sounds as it refills
hIi would return this should be under warranty
Jan 22, 2010 | Microwave Ovens
New kettle leaves a metalic tast to water after boiling.
Try different water. If you use tap water normally, buy a jug of water at the store. The pH may be wrong (particularly if it is too low) and leeching metal from the kettle. Good luck.
Jan 05, 2010 | Microwave Ovens
Can i use water boiled from microware to make formula milk for a baby that is 1yr old
I wouldn't recommend to use the microwave to boil water. Here you can read the reason why: http://www.snopes.com/science/microwave.asp
Water can 'explode' when heated in a microwave under certain conditions. Best way to boil water should either be using a water boiler or an old-fashioned kettle.
Jun 17, 2009 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
