Question about HP Compaq Presario C500t Notebook
My computer will not turn on. All of the light just flash, even the power button. Can I fix this problem myself?
    Genius:
  • 1,542 Answers
Hi
You could try this
plug in power supply and switch on
press power key and press F8 key at the same tim
hopefully this will bring up some options to repair you laptop
there are several choices there to try to fix it
i think the ist one i would choose to try would be the last known good configuration
it thats dont work i would then try
system restore back to when it was ok
then if that didnt work
try the
repair my computer
any of these options are worth a try
good luck
Posted on Mar 11, 2011
Sony bravia KDL-46EX725 6 flashing red light
Check the power supply. IT might have bad caps.
Aug 30, 2013 | Televison & Video
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
My computer will not boot up
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if it doesn't POST and the system doesn't boot anymore. It's meant for emergencies and is also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS, do not interrupt it under any circumstances. After a while the power button stops blinking, and the AA1 reboots shortly after. Wait patiently.
The BIOS has been re-flashed and all settings are reset to default.
If the AA1 doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again.
Jun 08, 2010 | Acer Aspire One PC Notebook
HP L1906 Flat Screen Monitor Power Light Flashing
http://www.fixya.com/support/t558081-monitor_will_not_power
Jun 01, 2009 | HP L1906 19" LCD Monitor
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Dec 04, 2008 | Office Equipment & Supplies
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Powering on
    OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
    Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
    I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
    Hope this works for some others.
    May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
    Acer Monitor 1706
    I replaced the 470uf 25v capicitors and this fixed the problem. I had 2 monitors exactly same with the same problem and it fixed both of them.
    Apr 21, 2008 | Acer AL1706AB LCD Monitor
    Computers & Internet Logo
    41 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
