Question about Sony VSPNS7 Network Media Player - BMP, JPEG, MPEG-2, WMV, WAV, MP3 - Ethernet
My VSP-NS7 are in service Mode and I can't get them to respond in anyway except should the service information screen, how can I reset the service mode?
Well, I haven't been able to get them out of service mode completely, but you can use Ctrl+Esc to bring up the start menu, or restart and press F8 to bring up the boot menu. If you select "use last known good settings" it may be fixed, but when I do that to mine, it just behaves like a normal computer for 10 mins then goes black and turns off with no warning.
Good Luck.
Posted on Mar 09, 2012
How do I fix "Filter VSP Communication Error" on my Aqua Pod
the VSP error is a code from the pump and not the controller or control system. the only way to clear this is to turn the breaker for the pump off for about 30 seconds to allow the electronics to reset.
Jul 09, 2014 | Hayward Pool Products Aqua Pod
Anyway to reset an ilo 42 inch flat screen
To make a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 04, 2014 | Televison & Video
Ns7 freezes or auto update firmware
Joshua's answer has nothing to do with your problem.
Jan 20, 2014 | Numark Industries Numark NS7 Numark...
I have a xda exec phone .the screen is blank with a serial up and 1.0v down the screen .. pls tell me what to do ..
Your phone is in bootloader mode. If you have not intentionally put it in that state, it might have entered it after an usucessful ROM upgrading process. Anyway, to get out of that state, just soft reset your device. The reset pin is located at the left side (in portrait mode, or at the back of the phone, when its screen is slided open). Just lightly press that pin with the stylus pen.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Feb 27, 2012 | O2 Xda Atom Exec Smartphone
What is a 350 code on a savin 8045 copier
This code can be reset be turning off the main power (orange rocker switch) for about 10-seconds and then turning the machine back on. If the error comes back up, then there is a definite problem with the machine and it should be looked at by a train service technician.
SC350:
ID sensor pattern test error
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Causes:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
Apr 01, 2011 | Office Equipment & Supplies
NUMARK NS7 / NS7/FX HARDWARE CONNECTION PROBLEM NUMARK ITCH CRASHED: ALL OF A SUDDEN, ITCH WILL NOT CONNECT TO COMPUTER, POWERS UP FINE BUT NO USB INDICATOR LIGHT ON . HAS TO BE INTERNAL UNIT PROBLEM...
Try it with another USB cable, it's more likely that the cable is bad than the Controller. If you don't have any success with the new cable, the controller probably has a malfunction and you will have to take it to the service to repair it.
Mar 07, 2011 | Numark NS7FX Motorized DJ Software...
My a6700y has developed a startup problem. it takes about 15 minutes from start to desktop. blank screen and no cursor until then. I have also had issues with freezing and applications not responding and...
Restart your computer. Press F8 several times while it's booting up. This should get you a text screen that allows several Safe Mode boot up options. In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
Safe mode helps you diagnose problems. If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes. If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
Sep 17, 2010 | HP Pavilion a6700y PC Desktop
Dark screen, invereter needs replacing?
I found a website showing how to remove the board and replace it through text and video. The site was very informative and didn't try to sell me an upgrade help service either.
Thanks anyway for responding.
Regards,
rstoney1
Apr 17, 2009 | HP Compaq Presario V2030US Notebook
Protron pd-dvr100
Fixed mine by opening up and replacing ide cable to the DVD burner. Was flashing hello. When opened up and touched the ide cable it would spin up the drive for a second. Its possible it was loose connection to the power plug in the drive but replaced ide cable just in case. Has been working perfect since. Very roomy inside and easy to do.
Feb 08, 2008 | Protron PD-DVR100 DVD Recorder
Sony VSPNS7 Network Media Player - BMP, JPEG, MPEG-2, WMV, WAV, MP3 - Ethernet Logo
213 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
