Question about Frigidaire FRS26F4C Side by Side Refrigerator
Door swings open too fast and not controllable.
How to install a door closer
Most come separated but if not separate the arm that holds to the door and door frame. Look to your installation manual or instructions to see the proper placement of unit to door. Depending on the door/frame you might want to pre-drill some holes for the screws after placing and marking the spots. Place the main piece back on an screw to the door. Mark out where to drill the arm to the frame of the door. Turn arm or use screws to adjust it to fit to the main unit without connecting it. On the bottom take the cap covering up the nut and turn it 30 - 45 degrees (or recomended by maker) with wrench HOLD it there until you connect the arm to the unit. Make sure that it connects properly. After screw the arm onto the unit and recover bottom with cap. Done!
If the door closes too swiftly, slams, or is hard to open then it needs to be adjusted by turning the S, L, or BC valves on the side.
S- how fast it swings from wall to 1-3" from door frame (hits you)
L- those 1-3" to the frame ( Slamming)
BC - controls how much force is needed to open the door
Apr 19, 2013 | Global Door Controls Residential Mini Door...
Car door got hit while open and wont close how do i fix it
The problem sounds like the hinge pin and bushings Its a heavy door and the bushings ware out see how far you can move the door up and down with it open if more then 1/2 of an inch this it the problen .You can get the pin s and bushings at any auto store for about 10 dollars usely the upper is the one . The pin is not hard to do its putting the damping spring back in that is problematic although the door will open and close with out it you just need to be careful about it swing open to fast the spring stops that from happening and you need a speical tool to install the spring
Feb 12, 2011 | 1999 Ford Expedition
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
Fridge door (kenmore elite side-by-side) swings open too fast past mid-point; freezer side ok.
adjust front leg adjusters down more to ****** the swing.
aif this was helpful please rate me
Thanks
imufo2@sbcglobal.net
Sep 05, 2010 | Kenmore Refrigerators
How to remove door panel from Saturn Ion
Depending on what side you would like to remove, you may want a friend to ride along with you as you drive at least 84 mph down a street crowded with parked cars. Once at full speed have your friend swing the door open (this won't be easy as you are going very fast) and then you as the driver can swerve and hit a parked car (or telephone pole) with the open door. This will result in the fastest and easiest way to remove the door. Hope this helped. Good luck.
Apr 15, 2010 | 2006 Saturn ION
Car door shuts too fast
the hinge has anchoring bolt and pin somewhere around the inner arm part of the hinge. tighten the bolt by the closing armature. also a body shop could easily remedy this with one of their wrenches ok?
Jul 25, 2009 | 1999 Oldsmobile Alero
The door to my dishwasher swings open to fast
You will need to bring the DW about 8-10 inches out from under the counter to access the door springs on the side of the unit.
Any questions, let me know
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | KitchenAid 24 in. KUDI01FL - Multiple...
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
Frigidaire FRS26F4C Side by Side Refrigerator Logo
109 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
