Question about Asko T701 Electric Dryer
My dryer sounds really loud and it takes about 3 hours to dry stuff - what's wrong?
    Scholar:
  • 158 Answers
It sounds like your squirrel cage, (this is the fan blade that moves the warm air) that attaches to the motor has broken. If thats not the case then pull out the dryer from the wall and make sure the exaust port is clean of any lint or debris. It is very dangerous to let lint build up in a dryer as this can cause a fire. I do not recommend using your dryer until you get it serviced and repaired.
Posted on Mar 12, 2011
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Dryer is Making a really loud noise
Your drum has bearings that turn it easier. They are worn or loose.you will need to have them replaced to get rid of the noise. How old is this dryer.
Feb 22, 2013 | Dryers
LOUD NOISE, SLOW DRY
Sounds like your belt is slipping. This would cause both loud and long time to dry. Replacing belt does not take too long, about an hour. Hope this helps.
Jun 01, 2012 | Dryers
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My dryer squeeks really loudly. SOunds like
Two areas that might squeak in this dryer are the tension pulley next to the motor and the drum support rollers mounted to the interior rear.
The manual below will cover disassembly of your machine to get inside in page 5-1 and 5-2. Other areas of the manual may or may not apply to your machine. Turn off power and gas before opening dryer case. Draw a picture of the belt travel around the pulleys before removing it. Good Luck.
Service Manual
Sep 09, 2009 | Maytag MDG2300BWW Electric Dryer
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Loud dryer
  • it sounds like a bad roller. if you know how to take the drum out of the dryer then you can do this repair. no special tools are required.
  • you can get step by step (with pictures) instructions at this site.
  •  www.fixitnow.com
Jul 02, 2008 | Kenmore 72982 Gas Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Asko T701 Electric Dryer Logo
52 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
