Question about Vacuums
I have a Eureka Power Plus vacuum, model 4702, type A. To start off, it never really had great suction. Marginal at best. Then today I was vacuuming and smelled something burning and turned off the vacuum. At that point, smoke started pouring out from the bottom of the vacuum so I layed it on it's side and the smoke cleared but I never found the source. Is it safe to turn on again after I let it cool down or is my vacuum "shot?"
  • Vacuums Master
  • 1,510 Answers
If it is the motor it may smell electrical and the motor is likely shot. It's very possible it needs a new belt. Your model has a stretch belt and they should be replaced at least every six months (even if it's never been used) because belts need to be stretched so far to be installed they will lose elasticity and slip on the shaft which can cause the belt to melt.
Posted on Jun 26, 2017
reddevil6
  • 1673 Answers
SOURCE: Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Posted on Jan 22, 2008
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
  • 64 Answers
SOURCE: Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Posted on Dec 31, 2008
nwj2468
  • 76 Answers
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Posted on Aug 22, 2009
Vac Belts
  • 701 Answers
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Posted on Jan 02, 2010
Why doesn't suction work on eureka
The hoses may be clear but debris could be clogging the point where it is discharged into the bag or container. There also could be a debris clog at the intake.
Sep 03, 2014 | Eureka Vacuums
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
332 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
