Question about Garden
We have a speck p30/43-130 water blaster pump looking for parts or somewhere to get it fixed thanks julie
2 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: I have a Speck E90-I
Regards, Tony
Posted on May 11, 2011
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
After i wash my clothes there is black little peices all over my clothes and in the bottom of my machine.i have tryed to do a wash with out clothes to clean it but it gets more in there. the first six...
Look for a filter, it may be breaking down. The supply lines should have screens. If they don't, disconnect them from the machine and run some water into a tub while shaking the lines to see if any specks come out. Once the lines are checked, go down the path, checking each hose for decay inside. Even check the pump impeller for decay. Check the specks to see if they are mold, which could be growing somewhere between the tubs.
Nov 26, 2013 | Samsung Washing Machines
My pump is making a screeeching sound
Most likely bearings. They will eventually break down. You might find someone in your area to replace them ... I suggest you find a back up motor.
Jun 15, 2013 | Speck Pumps COMPLETE E90II PUMP Part...
My 99 a4 is having an overheating problem
change your expansion bottle cap .the valve on it will be sticking. so water pressure goes up.
Jul 15, 2012 | 1999 Audi A4 Water Pump
My new ecotouch pump will not pump. It is a week old and the problem has occurred today. The lights on the pump indicate that it has power, there are no error flashes, but the pump does not switch on. When...
I would check the correct voltage is being fed to the pump (220-230v). Otherwise call this guy at the company, he was pretty helpful to me. Remember you have a 2yr warranty.
Ed
Chris Calise ? Manager - Pool Sales
Speck Pumps ? 8125 Bayberry Road Jacksonville, FL 32256
Phone: 904-739-2626 ' Fax: 904-737-5261
Toll Free: 800-BADUJET (2238538)
Email: c.calise@speck-pumps.com
Jul 02, 2011 | Speck Pumps Badu Ecom3 Variable Speed Pool...
MY E90 III SPECK POOL PUMP IS LEAKING BEHIND THE IMPELLER. WE JUST REPLACED THE HOUSING O RING. PLEASE ADVISE A FIX
Thank you for posting your question here on Fixya.com.
Replace the mechanical seal located behind the impeller along the motor shaft. Half is on the impeller and half is in the seal plate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 28, 2011 | Speck Pumps Pool & Spa
I used my water blaster 2 days OK and all was fine. I have just used it again and water is spraying out around the trigger. Is this likely to be a break somewhere inside the handle or is the O-ring not...
This sounds like it could be a problem with the handle. The part number for the replacement handle is 2.641-202.0 when you call your local kacher supplier/dealer to replace it just ask them to make sure that the part number I gave you will fit onto your high presure hose as the fiitings can change from older and newer models.
Jan 13, 2011 | Karcher K2.26 Electric Power Washer
Trying to replace a 4hp motor on a speck pump but can't remove the impeller, also, how is the seal plate attached? I've worked on several 3/4 to 3 hp pool pumps but this one is a first!
Id be happy to help if you could tell me what model speck pump you are working on.
There is just not enough information here.
Once you have the model, you can contact me @: adamh@newconceptchem.com for further assistance. I will give you the website for all the speck manuals incase you need it as well.
http://www.speck-pumps.com/html/usa/download_pool.html
thanks,
adam
if this post has helped you, please take the time to vote positively for me on this site.
Oct 16, 2010 | Speck Pumps Impeller 1hp Full1 12hp Up...
Speck Pump Model E90 has very little pressure when vaccuming pool
while I can not personally vouch for this company, they do stock speck parts.
http://www.poolpartsonline.com/m-44-speck.aspx
You will most likely need part # 2920741271 - O-RING (strainer tank) It's the o-ring that sits underneath the strainer lid and is most likely cause of your weak vac pressure. Make sure when you replace it, you use a good silicone based lube. It will help the lid seal better and prevent the o-ring from deteriorating faster if you used a petrol based lubricant.
Jun 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer. Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
May 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
