Question about ASUS P5S800-VM Motherboard
PC keeps on restarting
Greetings...
My PC keeps on restarting without error code. I already disable the Auto restart on error (Windows XP).
I inserted Windows XP CD, it boots from there but will restart after loading necessary Setup files (After NTFS….).
I also inserted Ubuntu CD still it restart after loading kernel…
I think it’s a mother board problem. (Memory and HD is OK, as I test them with other PC)
Thanks.
Eric
  • 1 more comment
  • eryqmb Jul 31, 2008
    OK i will check the power supply, thats the only part i did not check.
    I already clean the CPU except for the PSU.
    Thanks again and Post back the result
  • eryqmb Aug 01, 2008
    I already replace it with working power supply (from another PC) but still same result.
    I checked the PSU voltage and i got 12V and 5V - which is required. Anyway i will purchase a new PSU.
    Thanks
  • 781 Answers
Clean all fans and heat sinks on your motherboard as it could be rebooting due to overheating
if this does not work try this
If you can try this go to c:\ right click go to properties/tools/error check/check now/ when new box appears tick box to fix errors reboot on reboot windows will scan disk and fix any errors that are there and will automatically fix errors and reboot on restart check and see if everything is OK
Posted on Jul 31, 2008
  • 84 Answers
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
  • Styme
    Styme Aug 01, 2008
    All power supplies are not the same . I stated clearly you must make sure they are the same wattage or stronger
Wont start windows xp
Repair Window Xp by inserting windows XP cd in CD drive. After repair use a system utility software like RegInOut to avoid this error in future. It will also fix corrupt registry files and windows files.
Dec 28, 2011 | E-Machines Computers & Internet
How do i fix error ofoo:0244 and ofoo:1a44 (msg block 16867582, 46028639 & 111595250), please? I get these codes when I start my pc
I would suggest you first try the Start Up Repair for Windows XP.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.
2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.
3. When you see the blue screen, let the computer load everything and when it's done choose "To set up Windows XP now, press ENTER"4. Press F8 to agree to the License Agreement 5. Choose "To repair the selected Windows XP installation, press R"
Windows will then start the repair process. Do not worry all your data and settings will be retained.
If above solution does not work then,Use Recovery Console.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.3. When you see the blue screen, let the computer load everything and when it's done press R to repair Windows XP using Recovery Console4. On the Recovery Console, choose the installation you would like to log on to (for example c:\Windows)5. Type Chkdsk /p /r on the Recovery Console and your computer will begin to check the hard drive for error and recover data.6. Once Chkdsk is completed, type exit then press Enter. Computer should restart. No need to boot from CD at this point. You can take out the Windows installation CD.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Microsoft Windows XP Home Edition
Toshiba tecra m1 pc.. boot cycle keeps recycling... the windows logo appears then it auto restarts... will not finish loading windows xp same thing happens when i try to boot in safe mode.. any of the...
If it's rebooting when trying to boot into safe mode as well, have you tried "Last Known Good Configuration"? Press F8 like you do to go into Safe Mode, and choose this instead.
If this doesn't work, on the F8 menu, you can disable automatic restart. This will cause Windows to hang instead of automatically rebooting when it encounters an error. With any luck, it will display a STOP error for you. If you get this, comment with the error and I'll be happy to look that up for you.
If this helps, please give a positive rating.
Jul 05, 2011 | Toshiba Tecra M1 PC Laptops
Error code 0000135 unable to locate component basesrv not found
  • Insert the Windows OS CD in the CD drive of your computer, and then restart your computer.
  • 2 Press "R" on your keyboard when you see the Windows XP( if your OS is XP) "Welcome to Setup" screen. This will start the Windows XP recovery console. If you are asked to enter the administrator password, type it and press "Enter."
  • 3 Type the following commands one by one, without quotes, at the command prompt, and then press "Enter."
    "EXPAND drive_letter1:\i386\user32.dll_ drive_letter2\windows\system32"
    "EXPAND drive_letter1:\i386\userinit.ex_ drive_letter2\windows\system32"
    Replace drive_letter1 here with the CD drive letter of your computer in which the Windows XP setup CD is present (for example, E:), and drive_letter2 here with the letter of the drive in which Windows XP is installed on your computer
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Mar 25, 2011 | Dell Dimension 4700 PC Desktop
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
OR
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
Acer laptop keeps reebooting after win xp diagnistics menu (recovery console, safe mode, etc) also after changing boot order to boot from cd rom it does the same thing is it HDD or Bios problem, or both?
maybe the CD is not an original CD, insert and original CD to boot from......some CD's are counterfeited so for all PC their are codes that they udentify in order to reboot...have come across this problem more then u can imagine....i used an original SP1 XP CD to boot when finished, i insert a copy of an already activated version of windows then boot from the desktop then restart...
Oct 06, 2009 | Computers & Internet
PC is already starting but after a few seconds the PC restart its
1. insert windows xp at cd drom
2. boot the cd on windows xp then
3. after it boot on winxp choose repair
4. afte choosisng the repair it will ask you to enter admin password type (1)
it will prompt you to C:\ drive
5. type at c:\ fixboot
Jan 26, 2009 | ASUS Motherboard P5n-mx
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Does not copy large files
Sounds suspicsouly like a memory problem. When you allocate bad memory it will reboot your pc :)
Few things to check. First disable auto restarts on windows crashes. Do the following. (Assuming windows XP)
Right click My Computer
go to Properties
Click the Advanced tab
Click Settings for "Startup and Recovery"
Under "System Failure" Uncheck Restart
Now copy the files again and report back with the error code you get. IT will be something like 'yad yada yada 0x0000024'
You may want to also download memtest86, burn that to a cd and restart your pc. It will tell you if your memory is bad. Just look for red lines that say bad :)
Oct 06, 2007 | Samsung (P80G5200CK) 100 Pack 52x CD-R...
Toshiba Satellite M45-S351 PC Notebook
Do you hear the cd/dvd working? Is the machine booting to the cd? If so, boot using the WINXP cd. When it comes to the install screen say yes to a new install, it will ask you to accept the license, press F8. XP will then check for previous versions of windows already installed. If it finds one, select "R" to repair the existing copies of XP. You may need to reactivate your copy of windows and redo any updates but thats no big deal. Now if none of that works try the following: Can you access the start options menu when the machine boots by pressing the F8 key as the first toshiba screen is shown keep pressing F8 until a screen appears that shows: Safe Mode Safe Mode w/ Networking Safe Mode Command Prompt disable auto restart and some other entries Choose safe mode with command prompt. it will look like an old ms/dos window. type CHKDSK /R Send me any error messeges you have received or any other info you think may help. Let me (again) know what happens. Good Luck, Tim
Mar 15, 2007 | Toshiba Satellite M45-S351 Notebook
ASUS P5S800-VM Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
