Question about Keurig Elite B40 Coffee Maker
Trips groundfault recepticle - Keurig Elite B40 Coffee Maker
  • Anonymous Nov 24, 2008
    Same problem. repeatedly trips the ground fault.
Purchased a new one
Posted on Aug 01, 2008
Gfi recepticles no power all other lights working back to back bathrooms 2nd level
Have you reset the GFIC outlet? Was it tripped? Will it reset? If so, does the test function work?
Do any of the 120 VAC outlets work?
Is your inverter On and functioning?
Or are you plugged into shore power? Or on generator?
Jan 18, 2017 | RVs
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
Hotpoint fridge freezer ff200e
did you check your breaker panel water may have gotten to recepticle causing it to trip breaker or damage receptical. did you try using an ext. cord and plugging into a different recepticle. buy the way were you able to find where your water leak came from.
Oct 29, 2013 | Refrigerators
It is totally dead. It just stopped and now it wont work at all.
Did you check for tripped circuit breaker in elec panel. eg. does the duplex recepticle work?
Mar 16, 2010 | Washing Machines
Trips groundfault recepticle ocasionally
The pump bearing could be getting stiff or too many clothes are being washed in that washer if you want to believe that, that washer is a beast! Something is dragging down the motor enough to over amp it. Tip the washer back and remove the belt(no tools needed) turn the pump by hand and see if it is stiff. Look for bearing seperation. I have seen these guys lock slap up and never leak!
Feb 14, 2010 | Maytag Atlantis MAV8551 Top Load Washer
I have a Maytag Dryer, (Model #MED57TQ0), which no longer heats up. I have replace the (3) thermostats along with the temperature unit, and have checked the heating coil. It still does not heat up. Any...
This may sould odd but have you verified power at the recepticle of the power cord? If you can only get 110 / 115 VAC across the two power contacts of the recepticle vs 220 / 230 VAC then one of your breakers is tripped and you need to reset them. Also the motor switch controls the heating circuit. If the motor switch has failed the unit will not heat. Lastly there is a very real possibility that you may have a bad timer that is stuck in the air fluff or no heat position via defective internal contacts.
Jan 11, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Circut Breaker Trips
If the fault were with the product, the breaker would trip right away. You have either a poor electrical connection (power supply) or a weak or undersized circuit breaker. Free standing ranges usually use a 50 amp double pole breaker. Check electrical connections at breaker, range recepticle, and power cord to range to make sure all are tight. (obviously, have breaker off when making these checks)
Nov 23, 2009 | Refrigerators
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Keurig Elite B40 Coffee Maker Logo
54 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
