Question about Motorola Mobility MD671 Cordless Phone
Extension in use
Have a base station and two sub stations with handsets.  now i get no dial done and a message reading: "extension in use".  any thoughts?
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
On the base, open the menu and select
Register Accy.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Additional handsets will pick up calls from mobile phone but not landline calls
Try registering your older handsets with your new base station per the manuals instructions. Also your new base station might be transmitting on a different frequency or some other coded transmission is not recognized by your old handsets. Did the manufacture say the older handsets would work with the new system? They might not even if they did say so.
Jan 09, 2014 | Avaya 3920 Phone
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Feb 25, 2009 | Lands Phones
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Phone handset display continuously showing
Buy a new phone but not a VTECH piece of crap. Thier support sucks and you never talk to a person. It is all automatted.
Dec 13, 2007 | Lands Phones
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
No Dial Tone
I have found this free link on BT site for you
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Motorola Mobility MD671 Cordless Phone Logo
54 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
