Question about Toastmaster Kitchen Ranges
Toastmaster 36" gas griddle i
4 Suggested Answers
SOURCE: garland range griddle top
I have a 48" Garland griddle 4 burner thermostat controlled and I can't have it above low all the way across because it is so hot it burns my eggs. I have 1/4 of the griddle I can cook an egg on, if I turn the griddle where it should be at 250,300,300,350 the whole griddle turns black. I need a repair man to turn down the temperatures that it is set on. please sent a reply to janmid_86@hotmail.com with all the repair companies that are available in around Orillia/Barrie Ontario Canada Thank you
Posted on Jun 04, 2009
  • 93 Answers
SOURCE: what is the part number for the griddle gas valve
Call Jade / Dynasty ph # 800-884-5233
Posted on Mar 02, 2010
  • 205 Answers
SOURCE: I have an old Vulcan
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Posted on Sep 24, 2010
Miraclean pilot lighting
I'm not familiar with your particular appliance but all gas fired appliances have a thermocouple and igniter.
the thermocouple is designed to allow/prevent the gas valve from opening.
They commonly go bad on stoves and hot water heaters.
should you wish to attempt a repair yourself l
look on the Internet for a picture of the thermocouple for your unit , turn the gas valve off, then attempt to clean the thermocouple first with some medium grit sandpaper. Just some gentle rubbing a few times can take carbon buildup off.
Then try the start proceedure again. If the pilot light or burners do not light the the thermocouple is the least expensive component I can think of to repla e. usually less than $20 and very intuitive to do.
if that does not work depending on your ability you may either need to replace the igniter or gas valve. Or. Call a pro.
Be safe and keep the gas valve on the unit off until you are ready to restart each time
Hope this helps
May 18, 2014 | Keating Miraclean Griddle, Drop-In, Gas,...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
I have a vulcan60CL77R stove and the oven pilots keep going out. Also I need 6" pilot tubes for front burners. Can you help?
Yes we can help you. We service Vulcan and we love these units. May I begin to telling you that you have a great range?!! This is either your ignitors or the gas valves, but most probably the ignitors out if the pilots keep going out. I will check on the price and availability of all the parts that you need and respond to this request. Could you please send me your email address? We look forward to working with you on this issue.
Sep 29, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    THE STYAINLESS STEEL COOKTOP
    I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
    Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
    Kitchen Ranges Logo
    23 people viewed this question
    Top Toastmaster Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Toastmaster Kitchen Range Expert? Answer questions, earn points and help others
