Question about Saeco Royal Digital Espresso & Coffee Maker
Saeco Royal Digital not providing water
My Saeco Royal Digital is 2 1/2 yrs old (7,000 shots). It grinds and makes the noises but no water is coming out. Yes, it has water in the tank, no clogs. I've tried unplugging and replugging the power, and it will work for a few shots and then stop. Any ideas?
  • 515 Answers
If you try to make a cup of water, can you make a full cup or just a half?
Posted on Aug 01, 2008
The beans will grind but there is a bad clicking/knocking noise and coffee wont come out, water heats etc no error message
Hi
The dreaded clicking noise is usually the brew drive gears are broken. Usually caused by too much coffee in the brew unit that it can't compress ( 2 scoops of coffee). If you have ever done that, its broken but can be fixed.
Jan 03, 2011 | Saeco Royal Cappuccino Espresso Machine
I have been having trouble with the coffee coming out (vvery slow flow) so I descaled the machine today. Now its worse - it is just dribbling out - doesn't seem to have enough water going through. Can you...
2 things can cause this.
1. the grinder is set to fine abd you are creating to much pressure and the pump is having a hard time pushing water through.
2. You are getting a blockage in the brew head from coffee residue and oils.
Tru pushing the prre grind button and making a coffee without putting any coffee in. Blank shot. If it works its you grind. If not its your brew head. Needs to be cleaned.
Oct 03, 2010 | Saeco Royal Professional Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Mar 30, 2009 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Espresso & Coffee Maker Logo
196 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
