LG WM2455H i get ecl when I press tub clean for 3 sec. Is that right?
2 Suggested Answers
jan mczeal
  • 632 Answers
SOURCE: LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Posted on Jan 02, 2010
Washer leaves a large deposit of black material on sheets after washing
i think you model has a tub clean mode. i would try to do that. basically no clothes, no detergent, just fill the bleach dispenser and run the tub clean mode. press power and then hold in the tub clean button on the right for 3 secs. then press start.
Mar 23, 2015 | LG Wm2301hw Front Load Washer 4.2 Cu. Ft...
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Aug 18, 2011 | LG WM-2277HW Front Load Washer
Hi! We bought our WM2455H washer on February 1/2009 from Best Buy. Suddenly on several washes my clothes become spotted with brown grease. It does not occur at every wash, but what is happening. Please...
Do a tub clean cycle. Hottest water, no clothes, cup of bleach in washer, fill bleach dispenser with bleach, fill softener with bleach. Run once or twice. The 'grease' is actually residue from liquid detergent and/or softener. So stop using liquid detergent and switch to powdered (no residue believe it or not). Use plain white vinegar in place of softener. The acid eliminates the mildew residue and also helps get detergent residue out of your clothes. Good luck.
Dec 31, 2017 | LG WM2455 Front Load Washer
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Jun 04, 2010 | LG WM2277H Front Load Washer
Jan 02, 2010 | LG WM2455 Front Load Washer
I have the spinsense option activated. I want to turn it off and I want to activate the tub clean option. The won't work when I press and hold the button for 3 seconds. What can I do?
Push and hold Stain Cycle button for 3 seconds to cancel spinsense. Then, turn off machine. When you power it back on, press "Extra Rinse" for 3 seconds and push the START button.
When cleaning tub, do NOT use detergent--only use liquid chlorine bleach.
Jul 05, 2009 | LG WM2487H Front Load Washer
I have a LG WM2455H washing machine. I just noticed water on the floor and it looks like it is coming from some sort of an overflow outlet just below the cold water connection. Is there such a thing on...
What you speak of is a vent. To prevent this from happening, make sure you use only HE detergent, and no more than one tablespoon per load. (half that if you have 2X concentrate, etc.) You most likely have a build up of soap inside the machine. If your model has the tub clean cycle, run that with no clothes and some Whirl-away hot tub cleaner, 3 Ah- fresh tablets, or some Smelly Washer Cleaner. If no tub clean cycle, run that with the hottest, longest cycle. You may have to run it twice. Then use the correct amount of soap. (and not more than a teaspoon of fabric softener if you use it, per cycle)
Jan 02, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
