Question about Philips GoGear ViBE Digital Media Player
I was charging my media player and now it is stuck in charge mode?
    Genius:
  • 1,622 Answers
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Posted on Mar 11, 2011
issy2
  • 460 Answers
SOURCE: sansa media player
Surely it is there, u need to search more in electronics shops, If not i can make one for u...!!! Provided u let me know...!!!
Pass me a good rating buddy..!!!
Thankyou
Posted on Feb 16, 2008
SOURCE: Delstar Digital Mp3/Mp4 Media Player
Have you try different computer usb? It could be internal battery.
Hope this helps.
Posted on Aug 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I can not get my media player to turn on or charge?
Make sure the hold/lock wasn't accidentally engaged. If not:
You will have to go to this website and download the GPX Software Restore Utility:
http://www.gpx.com/store/p/190-ML648B.aspx
-Tha Mp3 Doctor
Posted on Feb 15, 2009
  • 17 Answers
SOURCE: Media Player 10 won't recognize it
i am using yp-t9b. try using the software from this website. it works for me.
http://samsung-media-studio.software.informer.com/
please rate me if the software work out for you.
thanks
Posted on Sep 22, 2009
Testimonial: "Appreciate your response. The problem turned out to be with Media Player. I installed the latest version again and all is well. Thanks again."
SOURCE: Device won't charge
mine did that too and i held all the buttons and pressed the reset button several times and it connected back to the computer.hope this helps
Posted on Oct 16, 2009
I want to download an album from my computer to my Insignia mp3. When I plug the player into my computer all I get is the charging screen. I want to get the album from media player.Jerry
When the player connects only with the charging display, there are 3 points that need to be checked:
Battery and cable connection
1. Connecting the player to the computer, the charging symbol should start loading; battery "green" or "partly green" indication. The player should respond with "OK to disconnect" = connection established correctly.
For proper charging and connection put the USB cable plug directly to the computer preferred at the back side: not through a hub or card reader.
MSC mode
2. The player is switched to MSC mode. MSC = Mass Storage Class. In this mode the device is seen as a flash drive also called removable disk, that can be accessed using Windows Explorer.
The Hold switch was in hold position on the top side, before connecting to the computer.
Disconnect the player and release the hold switch. Next the player should be in standard MTP mode. MTP = Media Transfer Protocol used for transferring files with media software.
MTP mode
3. The media software on the computer for transferring files is not installed or not working properly. Update or reinstall the media software.
Manual for Insignia NS-DV2G:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
When this didn't help the firmware on the player needs to be reinstalled.
For firmware see the Drivers in the Support tab of the next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Oct 01, 2009 | Insignia NS-DV2G MP3 Player
Stuck on "lock"
this happened to me but i'm not sure it will work for you.. try to put the actual switch into lock mode (push it firmly into lock mode) then slowly push it back to the unlock mode.. if it doesnt work the first time try it a couple of more times. it worked for me..
Feb 24, 2009 | Creative Labs ZEN Vision:M Digital Media...
Samsung YP-F1 stuck on 106.0 MHz - Radio Mode
open cover and use paper clip to reset it.
Feb 10, 2009 | Samsung Yepp YP-F1X MP3 Player
Stuck inshutting down mode
everyone probably knows this but I'm a novice! I reset it with the end of a paperclip!! Thanks.
Nov 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen 4g mp4 player
you should try to charge it or take it back to where you got it from.
Oct 02, 2008 | Creative Labs Zen Digital Media Player
Zen V Plus MP3
http://serviceman.site88.net/index_files/MP3Players.htm
Aug 03, 2008 | Creative Labs ZEN V Plus MP3 Player
Charging
I think, in stand-by mode of digital media player, charging will start automaticaly.
May 30, 2008 | Archos 405 Digital Media Player
Sandisk e270r stuck in the refresh database mode
The same thing happened to me. I just called the support number, and they e-mail you a firmware upgrade. It solved all my problems with it.
Feb 20, 2008 | SanDisk Sansa E280 MP3 Player
Philips GoGear ViBE  Digital Media Player Logo
689 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
