Question about Refrigerators
There is water dripping inside the refrigerator onto the top shelve, sometimes it runs all the way down to the bottom whirlpool model et18pkxf0 manuf. 10/97
    President:
  • 670 Answers
You either have a problem with the defrost circuit or the drain tube is blocked. To check you will need to remove the back panel from the freezer section to check. Behind that panel is the evaporator or cooling coils. If it is completely encased in ice, then the problem is that the defrost circuit has failed. To troubleshoot, see below. Otherwise check the drain tube for blockage. It is located just below the coils in the center Remove any debris and stick a length of wire down the drain to clear it of any blockage. Pour a cup of water down the drain and check that it goes down and enters the pan below the fridge.
The water source that is causing ice build up on your coils comes from the air. The coils are below freezing and the water in the air are freezing on to the coil. The defrost circuit in your fridge has failed. It is made up of three parts, the defrost timer, defrost heater, and thermostat.
The way it works is that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Posted on Mar 11, 2011
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
The freezer seems to be defrosting into the refrigerator instead of into the drip pan under the fridge. Water is leaking onto the top shelves and eventually falling onto the bottom shelves.
That sounds more like your cooling tubes are frosting up and then when enough air flow is restricted then it melts out into the refrigerator side.
If I am right, If you take some bare 14 gauge wire and insert it down the cooling tube and then put a loose "hook" around the defrost heater, this will solve the problem permanently.
Jul 25, 2011 | Whirlpool Refrigerators
Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from inside back (clogged drain?)
Apr 09, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water on inside of refrigerator
there is a dran for the defrost in the frezer that is cloged up need more infow to till u more
Dec 02, 2008 | Whirlpool Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
