Question about John Deere Garden
I have a john deere hd75 hydro its running slow not as fast as it was but it gradually speeds up when u run it. is there a filter or something i can do to speed it up
4 Suggested Answers
  • 138 Answers
SOURCE: my 1997 john deere just dont run as fast and hard
check your throtlle cable ... it is very possible that if the engine runs fine just doesn't run as fast as it used to that you throttle cable has slipped in the clamp and you need to adjust it ...
Posted on Aug 21, 2009
wireguy212
  • 1627 Answers
SOURCE: does a 1978 john deere 2130 have a 2 speed pto and
Remove the clip from the pto shaft by squeezing it shut,push it in some then pull it out.Turn the shaft around and put it back in making sure the clip snaps back in place.
Posted on Nov 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
I have a John Deere Hydro 175 riding mower that has this strange starting procedure.
fuel flow or blocked main jet
have the carby overhauled and check for full fuel flow
Dec 22, 2017 | John Deere Garden
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
My 1997 john deere just dont run as fast and hard
Aug 19, 2009 | Garden
Garden Logo
234 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
