Question about Video Game Consoles & Games
What is the code number for need for speed most wanted pc?
    President:
  • 1,623 Answers
Its the one you got with the game
Posted on Mar 11, 2011
Serial number
you can need to contact to service provider.
Aug 23, 2014 | Electronic Arts Need for Speed Shift 2:...
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Have a lucent partner 18D system How do I change
If your changing the speed dial numbers under the individual buttons thats done by pressing feature 00, the button you want to change the speed dial number on, and enter in the new number.
If your changing the system wide speed dial numbers, From extension 10 enter in feature 00, press feature then the 3 digit code for the speed dial bank (600-699), then enter in the new telephone number. Either press feature and the next 3 digit code for the next number or press feature 00 if finished.
Jan 25, 2010 | Lands Phones
Lost cd code for need for speed most wanted
You could search sites like youserials for a code for your game. However you will then still not be able to play online. Using these codes IS illegal if you cannot prove you own the game, so be careful doing this!
May 19, 2009 | Codegen GamePro 2400 (XDT:GAME-A) PC...
I need to know how to take the security code off my phone
program a speed dial key with your mailbox number, a pause then your security code.By pressing the speed dial key it will dial up your voicemail box and automatically dial your security code.
Feb 06, 2009 | NorStar T7316E Corded Phone
How to use speed dial and added numbers?
You most likely need a pause after the code. The usual code for pause is a comma so enter CODE*#,NUMBER
Jan 17, 2009 | Canon PIXMA MX310 All-In-One Printer
How do i edit my speed dials?
Redial, speed dial enter the code(60- 99) for system speed dial
(10- 49) for personal speed dial. enter the phone number or the number you want to program then press redial.
Aug 26, 2008 | Toshiba DKT-2010 Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
the intercom button. If you do not specify the external line, the system
5. Press HOLD.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
