Question about Vacuums
What bobbin do I use in a Juki DDL 8300 - Vacuums
  • Vacuums Master
  • 1,564 Answers
Hi there.
Nice machine... Here is a link to all the parts for your Juki DDL 8300
http://www.juki.co.jp/industrial_e/webparts_e/partslist2.html
Your bobbin's Juki part number is B9117-051-000
Posted on Mar 12, 2011
Bobbin is jamed, will not feed.
Hi. Sounds like you will first of all need to un-jam the bobbin. Is there a bobbin case involved? Perhaps it is the hook that is not moving? Start by unplugging your machine, then cut away any thread that is tangled or making a "birds nest" in the bobbin area. Use embroidery scissors or a razor blade, removing the cut off pieces as you do with a tweezer. As the tangle is removed, the bobbin / bobbin case should start to free-up. Once you can pull the bobbin out, clean out all of the remaining thread and strip the bobbin. When putting a fresh bobbin in, make sure the tail exits the bobbin case / hook through the slot and under the tension.
Sep 14, 2011 | Vacuums
Mmy bobbin case fell out of the casing spot and then the bobbin fell out. I don\t have a manual, used to know how to fix the problem simply but have forgotten. thanks for your help.
Hi. Find the end of the thread and pull it out, off of the bobbin a couple of inches. Hold the bobbin with the thread coming off of the top so that if you rotated the bobbin counter clockwise it would wind the thread onto the bobbin. Now take the bobbin case in your left hand with the stem in the center of the case facing toward you. Stick the bobbin into the bobbin case and, taking the end of the thread, pull it to your left while pushing back on it somewhat until the thread enters the slot in the bobbin case. Pull the thread so that it slips under the thread tension spring, pull a little more out, then reinsert the bobbin case until it is seated all the way in the hook. It will probably have a catch that snaps in place.
Aug 20, 2011 | Vacuums
Hi there. i am looking for the manual for the juki HZL F300. I lost mine and cant figure out how to get a zigzag stretch stitch to work
I could only find this, but there may be others.
Details: Juki HZL-F300 Sewing Machine Instruction Manual - Photocopied Version
http://www.sewingpartsonline.com/juki-hzl-f300-manual.aspx
May 27, 2011 | Vacuums
Jc penny model 1710 sewing machine, the stitching isnt tight
You do not say if it is the top stitches or the bottom stitches for the bottom tension, check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
For the top stitch, tighten up on the tension adjustment on the front of the machine which looks something like this:-
images?q=tbn:and9gctmqnuzdetdofn3rmptgx4d6h3wsbbewgyursvcfmpbxpewspjy
Apr 11, 2011 | Vacuums
The bobbin thread bunches up underneath the garment on Elna 2004 sp
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Apr 08, 2011 | Vacuums
Where can I get a free manual for a Tokyo Juki Industrial Sewing Machine # DDL-227?
Not sure if this is the complete manual but only site where I could find it available for free:
http://www.free-service-manuals.com/Sewing_Machines/Juki_DDL_227_Basic_Repairs_&_Adjustments_L98742/
Click on Download/Visit to receive the manual in zip format.
Mar 27, 2011 | Vacuums
Thread and bobbin both threaded properly, but bobbin thread keeps knotting. sewing at top looks great but bobbin side is just knots!! I have a Euro-pro sewing machine.
Mar 16, 2011 | Vacuums
Thread accumulating in the sewing machine from the under reel
I hope it is the area under the needle and around the bobbin that you are refering to. In that case check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 21, 2011 | Vacuums
Vacuums Logo
251 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
