Question about Brother Sewing Machines
Fabric will not feed. Just opened this machine. It's several years old but I have never tried to use it. No setting will advance the fabric. Please help.
  • Brother Master
  • 1,564 Answers
Hi there.
1. Check to the bobbin winder, is it in bobbin winding position or sewing position.
2. Look for the feed dog lowering switch, make sure they are in sewing mode.
Make sure you read that manual well. There are lots of tips and tricks.
Also letting a machine sit for long periods can cause problems. The oil even in a new machine can dry up and become like a varnish. If that is the case you'll need to have your machine serviced by a Brother professional (and then 1x a year from then on)
Posted on Mar 12, 2011
I have a singer sewing machine and my feed dogs won't advance my fabric?
Make sure the stitch length is set high enough to actually move the fabric, ie #2 or higher. Are the feed dogs in the raised position or have they been dropped for darning?
If it's an older mechanical machine, it may need a very thorough cleaning and Oiling. Old oil will cause the machine parts to seize.
Apr 23, 2017 | Singer Sewing Machines
The feed dogs on my sewing machine will not raise
if your question is that the fabric didn't feed when I tried a zig-zag stitch , well then this might be a normal thing to happen on your machine , some machines when set to MAX size zig-zag stitch retract the "feed dogs" as you call them so that the operator can hand move the fabric around under presser foot , this is task called "darn" and its usually for filling large holes in fabric (socks!!) and for adding embroidery too (special needle)
Oct 05, 2016 | Sewing Machines
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
Baby lock BL4-736d the feed dogs will not move forward
Make sure the stitch length is set long enough to actually advance the fabric. If set too short, the fabric movement will be very minimal. Also check that the presser foot pressure adjustment is set for the type of fabric you are sewing. The adjustment can be made for light- or heavy-weight fabric. If the presser foot pressure is too tight or too loose, it will have difficulty pulling the fabric.
Mar 16, 2016 | Baby Lock Sewing Machines
Problem with feeder dog
if you have the manual to the machine then you can see where
the feed dog lever is & check to see if it's in the up position
also you can take the machine in to be checked to see if the feed dogs
need repairing or replacing
Jun 12, 2012 | PfaFF Sewing Machines
Kenmore 1764180 will not advance fabric, feed dog just doesn't appear to be moving. This has been happening intermittently but now will not advance at all and have been unable to get it to work. Any...
How old is this machine? At zero setting of stitching length the fabric wouldn't move. There may be problem in stitching length mechanism or the fabric feeding mechanism is wornout.
sonsunny
Jun 18, 2011 | Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Stitches don't feed properly
Remove the foot and the needle plate. Check the area where the stitches are formed to see if there are any rough edges on the plate or stitch finger. Sometimes you will find a crack in the plate that is hidden under the foot. While the foot is up, the gap closes but when it is lowered and fabric is trying to feed the crack opens and the rough edge won't allow it to advance.
Jul 13, 2008 | Husqvarna Huskylock Computerized 910
Fabric doesn't advance
Have you checked your feed dog position? The fabric will not advance if the feed dogs are in the down position. For the machines which don't have the raise/lower feed dog capability, there is a plate that covers the feed dogs and must be removed to advance the fabric when sewing.
Nov 06, 2006 | Bernina 1008
Sewing Machines Logo
114 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
