Question about Fluidmaster Plumbing
I have a fill valve that says Fluidmaster 747. when tank goes to fill it sprays water out at the top
    Scholar:
  • 158 Answers
There should be a small flexible tube/hose that came with this and goes over where the water is spraying out, it should look like a little nipple, the hose goes on there and then to the white tube appoximately an inch or so in diameter that goes to the bottom of the tank where the flapper ball is connected. The small flexible tube is supposed to connect to the top of the larger tube via a clip so-as to fill the toilet bowl back with water. If everything is connected like it's supposed to be then you might have a cracked fluidmaster.
Posted on Mar 11, 2011
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
Why is fluidmaster 747 loud when filling the tank?
Water rushing through a small opening creats turbulence and noise. Only way to quiet it down is to restrict(slow down)the water volume by closing the supply valve partially.
Nov 01, 2014 | Plumbing
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
Fluidmaster model 747 flush valve is spraying water out the top
Hi tdechill...
Make sure the hose that goes to the top/side of the fluidmaster is in the overflow tube of the water tank, if it is then It should not spray water from the top, it is faulty and needs to be replaced.
Please take time to rate me
Aug 18, 2011 | Home
After flush tank refills very slowly
Make sure that any valves that you shut to install the fill valve are fully open after the installation.
If that doesn't work, the following is from another fix your stuff site:
Shut off water supply. Lift the rod arm and remove top cap assembly by turning 1/8 turn counterclockwise. Using a straightened coat hanger, carefully clean out the inlet passage of the Valve.
If these don't help, check the model number of your Fluidmaster and include that the next time you write.
Dec 09, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I installed a new complete Fluidmaster and filled it up with water but when flushing water comes out under the tank not under the toilet though.
probably needs a "doughnut" tank washer under tank..or try tightening the tank bolt..fluid master comes with a little rubber hose that goes to overflow tube
Nov 25, 2010 | Fluidmaster Plumbing
After tank fills up, water continues to flow a little. How do you fix it?
Replace the top cap of your fill valve, or just the fluidmaster seal disc. Here is a link to the Fluidmaster fill-valve Instructions.
Sep 06, 2010 | Fluidmaster & Fits-All Faucet Connector
How can I adjust the water level in the tank?
With a standard Fluidmaster fill valve, on the side of the float there is a rod that controls the depth of the float. On top of that rod is what looks like a phillips head on a screw. You can use your fingers usually, but if you would like you can use a screwdriver, simply move the float level up and down by screwing either clockwise or counter clockwise to change the level in the tank. Flush a little water after making the adjustments to guage the water level when the fill valve shuts off. Good luck
Aug 14, 2010 | Fluidmaster & Fits-All Faucet Connector
How do you replace a fluidmaster 200A fill valve?
SHUT OFF WATER.REMOVE WATER FROM TANK.UNSCREW SUPPLY LINE NUT TO FILL VALVE, (UNDERNEATH TANK). UNSCREW FILL VALVE NUT FROM FILL VALVE, (UNDERNEATH TANK). REMOVE OLD FILL VALVE. INSTALL NEW VALVE IN REVERSE ORDER.
Dec 14, 2009 | Plumbing
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Plumbing Logo
1,766 people viewed this question
Top Fluidmaster Plumbing Experts
Mack Baxter
Andrew Bugbee
Tom Chichester
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
