Trying to connect SC-HTB10 sound bar to a Sony Bravia TV. I have ATT U-Verse as my cable supplier. I connected the HDMI correctly, set my TV sound to audio system, but no sound. Help please?
SOURCE: Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Posted on Oct 18, 2007
  • 133 Answers
SOURCE: I have a new Sony
It is your BE2 Board, it has a problem, iv seen this befor, if it is brand new, i would call sony, they should send out a service center, and Sony will cover the repair
Posted on Jan 10, 2009
  • 5 Answers
SOURCE: sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Posted on Feb 10, 2009
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
How do i connect sony mobile phone to sony tv
Watch and listen to your Xperia TM content on your TV
Open this link & watch this video will let u know how to connect sony mobile to bravia via mirroring.
Thank You
Dec 01, 2014 | Sony Cell Phones
I have att u-verse cable box and connect the hdmi cable to my hp2310m moniter that have a hdmi connection the problem the sound is very low
you may have to go into the control panel and change audio settings to config sound to play louder..are you using 3rd party drivers or OEM?
Jan 23, 2011 | HP Computers & Internet
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
40" Sony Bravia has intermittent audio failure.
I have a KDL-46VL130 with the same problems. Audio on the HDMI connection turns on and off intermittently when I have it connected with my ATT Uverse rcvr. I check w/ Sony online support and they led through the standard troubleshooting process ... which I knew going in would not fix the problem. Ultimately they told me to try a new HDMI cable first, or try a different video source for the HDMI, other than my ATT U-Verse reciever and see if the problem persists. Having seen other articles on this issue, i am almost certain that is not going to fix the problem... and to think that I paid $2000 for this thing.
Dec 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I can't play new wii via Sony Bravia TV and U-Verse DVR. Have power, synced controller - can't find correct channel
First make sure you scored in the correct cable entrances to ТV. Make sure you are on the right channel/AV/HDMI setting, if you have a multiple HDMI ports make sure you are on the right HDMI selection.
Nov 04, 2009 | Nintendo Wii Console
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
I have a new Sony Bravia 32" TV and when the Verizon Cable was installed with HDMI connection, TV had sound but now picture; instead it gave me a green color. The same Cable was connected to another TV...
Jan 10, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
