Hey folks my tevion lcd4203id is faulty the tv wont switch on no power light how do i fix or find whats at fault
, hi ,, im having a similar problem with the same unit.
it was working fine and all of a sudden the pictured started to look a bit weird , the best way to explain it is probably like this.
ever seen a computer running windows in 256 colour mode?
the picture itself is clear as a bell and the tv works perfectly , but everything looks like this ,
any ideas people?
Posted on Dec 28, 2013
3 Suggested Answers
  • 8909 Answers
SOURCE: 40" tevion lcd tv. modek no lcd 4040.wont come out
It should be fixeable. Does it do anything now?
I would blanket change them all.
Posted on Feb 18, 2011
ekcnoel
  • 998 Answers
SOURCE: Tevion LCD4203ID, turned televsion on
Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Posted on Sep 04, 2011
How can i fix my sony tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 02, 2016 | Sony Televison & Video
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
I HAVE AN EMERSON LF391EM4-4 WHEN I PLG THE SET TO POWER THE RED LIGHT FLASHES BUT THE TV WONT POWER ON/WHAT CAN I DO TO FIX IT?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Aug 19, 2015 | Emerson Televison & Video
What does it mean when green power light turns yellow and blinks on and off. tv will not come on
Dec 03, 2014 | Televison & Video
Neither the remote or power on/off switch works to turn on
I'm assuming you tv doesn't turn on but you have the red light indicating power , it's possible you have more than a faulty switch , common fault is the power board has blown one or a few capacitors , you could try replacing the power board on the tv but some tvs will not start if there are other faults , namely faulty inverter , faulty power board , if the display is faulty , it'll be cheaper to buy a new tv
Sep 19, 2014 | Toshiba REGZA 52RV530U LCD TV
Television colour flash fault
Hi Nathan
Contact the authorized service center. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 08, 2014 | Televison & Video
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Can i buy the main board for a Lcd4203ID Tevion TV
Sure, if someone is selling it and you agree on the price...why not?
Oct 02, 2012 | Televison & Video
Tevion LCD4203ID, turned televsion on by mains plug, no power being received by television. Have tried different mains adaptor so is definately television. There is no red light or green light on...
Sep 04, 2011 | Televison & Video
Feb 18, 2011 | Televison & Video
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
Electro Med Services...
