Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Freezer is growing frost nd refridgerator not cold
    Problem Solver:
  • 10 Answers
There might be a problem with the thermostat and You can not fix this problem yourself So, it is better to call a Freezer Repair Expert near you as he can better help you.
Posted on Mar 25, 2011
Freezer is frost free yet it is icing up its a refridgerator
I would recommend that you turn either the freezer down or the fridge. This is somewhat normal, even frost free units will produce some frost, and this is mainly due to the temperature being too cold. Some minor adjustments and you will be fine.
Mar 20, 2011 | Westinghouse Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
I have a Kitchen Aid refridgerator. My freezer
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Jenn-Air JCB2280HES Side by Side...
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
