Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
I have a Whirlpool washer that will fill and start to agitate for a few minutes or less then stops with the washer completely filled. and then I cannot get it start agitating even when re-adjusting the knob to go further into the wash cycle. If I let the unit sit for a few hours to a day I have found that re-starting it often will result in the until successfully washing that load. It has not shown any difficulty with spinning but in the wash phase I have a great deal of difficulty to get the unit to agitate/drain. Often I end up removing all the clothes come back later and reset it to the beginning and it will run the whole cycle. What part is most likely going out the drive/motor coupler or is it more like the Drive Motor? The Whirlpool is a Ultimate care II model LSQ8543JTO
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 1314 Answers
SOURCE: washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Posted on Jan 11, 2008
  • 85 Answers
SOURCE: Nothing wierd...just no rinse/no spin/no drain with the whirlpool
sounds like you have a bad lis switch asm.
Posted on Dec 16, 2008
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
aborcass
  • 2651 Answers
SOURCE: WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Posted on Jan 25, 2009
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Washer fills and agitates will start to pump and spin then stops let sit for a few minutes and it will try to spin again replaced both belts this is a maytag top loading about 8 yrs old
Either the program switch or the transmission has failed. The transmission is probably a lousy Whirlpool part and have had them fail in only a few years of light service. To eliminate the program switch, use a different cycle setting to see if it can complete any of those available. If not, then it's probably the transmission.
Jun 13, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loading washer fills up but won't stop filling on the rinse cycle. Doesn't do it every time. Sometimes it will start filling again after it agitates for a few minutes.
Check the fill control device and the tube that goes to it. Make sure there is not any debris in the outer tub where the tube connects. You may be able to push the drum aside to check.
Apr 27, 2009 | Maytag PAV2300 Top Load Washer
Agitator not working
There are several things that can cause your machine to fail to agitate. First of all, you need to ask yourself a few of these questions:
1. Does the washer fill normally, initiate agitation cycle and just the agitator is not moving? If so, the transmission and motor coupling are likely good and the agitator has probably worn out the dogs that cause it to grip properly. The agitator dogs will need to be replaced and you shouldn't need a new agitator. (rough estimate = $5.00 to $6.00).
2. Does the washer fill normally, but stops when the agitation cycle is to begin? If so, I would suspect a faulty lid switch. The lid switch will allow the washer to fill, but will not advance the timer beyond that point on some models. (rough estimate = $35.00).
3. Does the washer fill normally and makes a loud grinding noise when the agitation cycle begins? If so, I would suspect your motor coupling is bad and needs replaced. (rough estimate = $18.00 to $20.00).
4. Does the washer fail to fill at all? If so, I would suspect a bad fill valve, pressure switch remaining shut off and/or timer. (rough estimate for fill valve = $35.00, timer = abt $100.00).
These questions are not all inclusive, but these are some of the more common problems I have encountered. If you can provide me with a little more symptom elaboration, I can lead you in the right direction and get a part number and a better price for you. I will need your EXACT model number (located somewhere along the lid opening. Post back with your comments if you need my assistance. A good majority of the problems associated with Whirlpool top loaders can be easily repaired by the average consumer without assitance from a repairman. I hope this information is helpful to you.
Jan 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill but won't "wash"
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer clothes
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
