Question about Samsung Heating & Cooling
I have a Samsung ductless mini split system model AQV12JA. After a recent power outage the unit will not restart. The yellow diagnostic LED is flashing in the outdoor unit which indicates an error code of "capacity mismatch". From what I have found on other websites it appears that this is a known issue with Samsung units and that you must re-enter the option code using the remote control to reset the unit. My manual lists the option code as 09 C7 77 17 F2 5D. Unfortunately the same manual which includes instructions for my remote control gives instructions to enter only 10 segments (digits). And the instructions given don't seem to match the remote either, because after entering the segments when I get to the validation step the remote is showing zeros. I guess what I'm trying to say is that the instructions given in the service manual that came with the unit do not match the remote that came with the unit. My remote has two part numbers marked on it DB93-03012N and ARH-1409. If someone can tell me the proper method to enter in the option code for the AQV12JA using this remote I would be very grateful. Thanks!
  • bckickass02
    bckickass02 Jul 23, 2012
    The correct code is 9C 77 77 F2 5D, after entering the 10 digits codes, push 3-5 times power button on the remote onto the unit direction. Remove the batteries and reinsert again . :)
  • 3,083 Answers
Since you may not receive a specific answer to this problem, I will offer some advice that may help.
You really need to get Samsung to rectify this issue. Oftentimes, there are mistakes or poorly written manuals, which required you either to figure it out by trial and error, or having Samsung clarify.
Here's Samsung's support site:
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=samsung+support&cp=10&pf=p&sclient=psy&site=&source=hp&aq=0&aqi=&aql=&oq=samsung+sup&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=1ababa747787e995
Good luck, and hope this helps.
Posted on Mar 12, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What kind unit is
This type of unit is called a Mini Split Air Conditioner.
Hope that helps you check us out at Air Duct Cleaning
Nov 02, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
No power at interior unit. power everywhere else
If this is a mini split ductless there is a control wire with 3-4 wires inside (normally red, white, blue and green) that is connected from the outdoor unit to the indoor unit. This wire feeds voltage from the o.d. unit to the I.d. unit. If all connections at the o.d. unit are good, then check for voltage at these connections at the o.d. unit. If no power at these connections then a circuit board has faulted. Call a tech. and have a tech support number ready (1-800#) in case your service tech don't have it.
May 12, 2015 | Sanyo KHS0971 9,000 BTU Ductless...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
Hello just replace the pcb for a mini split model# AQV12JA but not I have all the lights on indoor unit blinking. What's going on? Thanks In Advance
Make sure that all of the plugs are seated - take them back off and reseat them. Second, start looking for a dead short in the controls. If that doesn't fix, I would suspect a bad replacement board.....
Sep 01, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
1,135 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
