I have a Tivoli iPAL and need a power cable for it. Not the three pronged on. Where could I purchase one and is there a local dealer in my area. Woodinville, WA?
  • 961 Answers
Http://www.tivoliaudio.com/products/accessories/power-supply-for-pal-and-ipal.html
Hopefully this will help you, I teird local dealers to no avail.
Posted on Mar 11, 2011
Testimonial: "Thanks. I shall ahve my charger in a few days."
Why has my Tivoli iPal AM/FM Radio stopped working?
Try removing the battery and power on. If it does not on, replace the unit, a new unit would cost you less that a repair of this unit
May 18, 2014 | Audio Players & Recorders
Tivoli radio
An internal fuse may have opened or there could have been spontaneous power supply failure.
Dec 08, 2017 | Audio Players & Recorders
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
I have a Tivoli Ipal and I have a broken antenna. I have a new replacement antenna but need to install it. help.
Bought a replacement antenna for my iPal for about $5 plus a couple of dollars shipping. Installed it in 5 minutes without taking the back off of the radio. No big deal. Simple, cheap, fast.
Jan 20, 2011 | Tivoli iPAL AM/FM Radio
The battery is fully charged. It works while connected to the mains, but if i turn it off and remove the power cord (so it works on the batteries) it won't turn on. However, it will turn on while connected...
Change the battery in it. It can be found online. It is easily accessed on the back of the radio, by unscrewing 2 philips screws. I had the same problem with mine, with an old battery. Once turned on, I could unplug it and it would play for 12-14 hours. Apparently the iPal needs a higher voltage when it turns on, so your old battery is not able to deliver that.
Nov 19, 2010 | Tivoli iPAL AM/FM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
To install electric stove ...what is the recomended and required amps number
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573502
Generic problem for all Kitchen Ranges
Posted by kukla61 on May 05, 2008
To install electric stove ...what is the recommended and required amps number
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
Most of the electric ranges have either a 3 prong or a 4 prong gray electric cord that usually has a 220 plug, follow the color wires and match them to the wiring panel in back of the range. I am not sure on the amps, you may want to check with your local appliance dealer and also the customer’s owner’s manual, so check on the plug in the wall and then purchase the correct plug according to the number of prongs in the outlet and once installed level the range with the leveling legs. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. You did not give me a brand name or model # so check with the silver tag on the actual appliance and sometimes that will tell you the number of amps.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Battery won't charge
this is what you should do: charge it.. then when it's still connected to the power switch it on.. then you can remove the power plug and enjoy it for hours...
I know it's weird...
Nov 12, 2006 | Tivoli iPAL AM/FM Radio
207 people viewed this question
 Grubhead
Grubhead
