Question about Kitchen Appliances - Others
Howden fridge door hinge broke , 18 months out of warranty . Fridge has now been discontinued so no hinges available to replace . Should they keep spares for a set lengh of time ? .
  • 1,564 Answers
Check with your local Attorney General or equivalent. In the mean time does it look like the Hinge could be repaired by a welder?
Posted on Mar 12, 2011
E522B - About 6 mths ago, a the clip on the bottom hinge of the freezer door broke into two , depositing the one end on the kitchen floor . Fridge seemed to operate OK regardless. Today, the same clip on...
I know this thread is super-dead. Mine broke off a while ago and it means the door doesn't stop until it is 180 degrees open. The bit that broke off is the door-stop part of the lower hinge.
I just put this here in case it helps someone else stumbling upon this thread as I did.
As far as I can tell, the part is available somewhere. I am off to find out where, next...
Aug 14, 2012 | Fisher and Paykel Active Smart E522B...
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
My refrigerator door won't close. How do I know if it is a hinge problem? How do I fix a hinge problem?
Newer model KitchenAid refrigerator doors have a two piece cam on the lower hinge that assists the door in shutting. This cam is made of plastic and the weight of the door tends to grind away this part quickly. To see if you have the cam and it's worn, lay on the floor and compare the freezer door to the fridge while someone opens it. If the cam is there, you'll see the door rise up about a 1/4" when you open it.
If the fridge is a newer model, a call to KitchenAid customer service will get you the parts. If it is out of warranty, they will send you the parts for free if you politely point out that an expensive fridge shouldn't fail like this so quickly.
This is an easy part to part to replace, though it does require taking the door off to do it. Screwdriver and a small socket set is all that is required. 15 minutes to complete the task, including taking the fridge contents off the door. :-)
Jan 17, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Kitchen Appliances - Others Logo
71 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
