Question about Kirby Vacuums
Kirby vacuum suddenly appears dead. It worked this morning, but this afternoon would not even turn on!
  • howarddenn Aug 01, 2008
    Thanks much Rob. Your suggestion to check the safety switch on the front of the unit was right on target. The lever that activated this switch was not seated properly, and when I adjusted it, power to the vacuum was restored! Thanks again.
  • 97 Answers
There are a few things to check:
There are safety switches mounted on the body of the machine designed to prevent the machine turning on when it is not fully assembled. Ensure that your bag unit is snapped completely into place, (with the rear of the emptor assembly nearly flush with the body of the machine,) and that the front nozzle assembly is mounted correctly.
Also check that the power cord (immediately aft of the bag unit,) is pushed completely into the machine.
If the switch does not feel responsive, it can either be that the little metal "pole" (for lack of a better description) is not attached to the main switch assembly correctly, which will require you to open the entire housing to check.
Those are the simple things to check, otherwise it may need a switch, cord, or motor replacement. Checking continuity on these items with a VOM will allow you to determine the cause.
Posted on Jul 31, 2008
Why does my kirby g4 sander not work
dirt inside or missing lubrication insite the bearings.
Jul 02, 2014 | Kirby Vacuums
I have Kirby vacuum cleaner that all of the sudden won't turn on. I know the power cord has been stepped on a few times through it's life but it doesn't appear to have been pulled enough for it to not get...
Brocken switch could be the problem but power cord most likely check continuety on both wires from the plug to the unit also does have fuse have you checked?
Sep 26, 2017 | Kirby Vacuums
I have received a vacuum with my house rental to use-a Kirby Generation 3. It turns on but the brush doesn't appear to be working. I would like to take it apart to check the belts but can't find...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Sep 22, 2011 | Kirby Generation 3 Bagged Upright Vacuum
The on/off switch on my kirby g-3 vacumn needs to be replaced I would like to know the best procedure.
Get the parts ... locally or at some place like then set aside a Saturday afternoon in a quiet place with screw driver, pliers and a box of band aids and go to it. will also provide you with details of the actual procedure at hand.
That is what I think
Oct 05, 2009 | Kirby Generation 3 Bagged Upright Vacuum
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Sep 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Vacuums Logo
149 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
