Question about Dewalt DW309K Factory Reconditioned HeavyDuty Reciprocating Saw Kit
I have Dewalt DW309k .was working fine all of a sudden in the middle of the job it just stoped working.nothing is binding or jammed .I though it was the electricity breaker however all the other tools work.
    Sergeant:
    Champion:
  • 250 Answers
It could be a bad on off switch. You have to take it apart and check the switch whith a ome meter. Also check the power cord where it goes in the saw for voltage. While it is apart make sure you can spin the motor by hand. Also check the brushes on the motor they should be under screw caps.
Posted on Mar 11, 2011
The drill suddenly just stopped working in the middle of the job - the battery is good but it doesn't seem to be getting any juice the worklight will not even come on.
If you can to take apart the drills, put the battery directly to the motor. If it is turning the , probably the switch is faulty. If it is a controlable speed drill, check the FET transistor. I recently replaced the FET in a Ryobi drill. Cost $5 and workin glik ebrand new.
Feb 11, 2015 | Dewalt 18v Cordless Hammerdrill Dcd970
Dewalt Mk246 won't run. , It's Brand Nu was
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
Apr 21, 2013 | Air Tools & Compressors
How do i square the table to the fence on a dewalt table saw?
Normally we adjust the rip fence so that it toes out 0.10 mm over the lenghth of the rip fence. Some models have to have the trunion shimmed or the table removed/adjusted to achieve this. The toe out ensures no binding but doesn't effect the measuring. Note. adjusting the trunion is a large job.
Feb 11, 2012 | Dewalt DW744X 10" Portable Table Saw
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
I own a CP1215 which is barely a month old. It worked fine until yesterday. Suddenly, each time I attempt to print, it gets stuck as it comes out. I followed a tip I found online and close the back tray...
This might not be a solution, but rather something to get your job done if nothing else (if it works):
Try using the "manual feed" tray instead of the paper tray. Depending on where the jam is occurring in the machine, it could bypass that spot and print fine.
Best of luck!
--JK
Mar 03, 2011 | HP LaserJet CP1215 Color Printer
DW718 miter saw. The blade rotates but does not cut once it makes contact with any resistance. It is as if a cotter pin is broken. How do you repair the problem and what parts would I need. Was working...
I have 8 differant saws but not a dewalt and have not ever heard of or seen a shear pin on a drive shaft of a motor its a stright shot through the motor to the brushes and there is no gearing or reduction box I would say check the blade connection and washer assembly or the end bearing on the shaft may be worn out and binding under a load. Dose the blade spin true or can you wiggle it from side to side and feel play in the bearing I soppose it could also be some kind of electrical issue where something is shorting under load but that would still bring me back to movement in the shaft that is binding the motor.
Jan 02, 2011 | Dewalt Saws
Hand crank binds
The bearings may be packed with sawdust. Clean it out, look for any place where there could be movement and squirt WD40 in those areas, while cranking. This may free it up.
Apr 04, 2010 | Dewalt DW745 10" Compact Job Site Table...
The printer suddenly stopped printing in the middle of a job. Now whenever i try to print it says job waiting and when i try to delete the current prints it says deleting but stays on saying that and...
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | Lexmark Z640 InkJet Printer
Dewalt DW309K Factory Reconditioned HeavyDuty Reciprocating Saw Kit Logo
156 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
