Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
I have a 19 hp kohler courage on my toro zero turn mower. it wont start. i sprayed fuel into carb and it started but as soon as it was burned it died. I checked fuel pump and it was working good. i checked fuel lines and there is no problems. what do i do now?
  • 4,340 Answers
This sounds like the carb is plugged. Sometimes fuel thickens and makes globs...
If you verified the fuel flow to the inlet of the carb, then you need to take the carb off and open it up....
So, what needs to happen is you blow out all of the passageways with carb cleaner.
Any adjustable jets: make note of the position it is in, and FINGER TIGHT turn it clockwise until it closes (typically 1 to 1 1/2 turns) SOOOOO, you can set this jet back to the same positon....when finished blowing everything out, bottom the jet and back out the number of turns out, noted for that jet.
Open the float chamber, and clean as necessary, Inspect the float adjustment: invert the carb, and observe the angle of the float, relative to the carb body.... Usually almost parallel, but not necessarily.
Inspect the inlet valve, and clean those areas...
I usually use all new gaskets and valves, but if you are not a carb person, cleaning is effective and I think old gaskets may be okay, if not torn or damaged.
Posted on Mar 11, 2011
    Problem Solver:
  • 8 Answers
Check float in carb make sure fuel gets in float
  • 2Manytattoos
    2Manytattoos Aug 13, 2014
    on the bottome of the carb bowl you will find a selinoid. it will have one wire going to it. unsrew it and either replace it or take a pair of good wire cutters and cut the little rod that comes out. If the rod is not sticking out you can pull it out but with your problem it should be out already.
  • 2Manytattoos
    Sorry about spelling. I was in a hurry.
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Why wont briggs and stratton 12.5 h run without choke?
Carb is dirty and before you tear it really apart take the fuel bowl off if it has one and clean it real good and blow the dirt out of the fuel jet which is the bolt that holds the bowl on .That may be most of your problem. Drain the old gas and replace with fresh as well. Won't hurt to run some cleaner through as well.
Jun 22, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a 2005 Dixon zero turn mower the motor is hard to turn over but once it starts turning it turns fine when the motor starts it will only idle and not accelerate it has a 14.5 hp Briggs and Stratton...
sounds lie it's starving for gas.
Does this engine have a fuel pump or is the gas gravity fed???
Some engines this size do have fuel pumps.
I'd also take the bowl off the carburetor and check the Jet.
Aug 10, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My zero turn Toro dont want to start, the battery is good and starter
On mine the arms have to be out the blades have to be off and the parking brake has to be on for it to start hope this helps.
Jun 06, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Fuel keeps coming out of the carb
replace the needle valve in the carb the fuel we get now melts the seal off the valve then change the oil
May 20, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Will not reach top hp exhaust cherry red
Your carb is in a lean codition which causes the exhaust to glow. I would recommend having repair shop rebuild carb .This way you get it set properly and should have to make only minor adjusments .I also recommened running a fuel stabilizer all the time .
Feb 04, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Have a 3 year old 42'' Toro Zero Turn never had a problem. Was cutting grass and it died. Will not start, no fire and does not seem as if it is getting fuel ? Does it have a fuel pump or could it be...
That unit has a fuel solenoid that is attached to the carburetor bowl. Over time this solenoid can act up at odd times. You can take off the air filter cover and manually choke the unit and see if it will start up again. I would take it in to your nearest TORO dealer. On the website it has a dealer locator to find the closest one to your zip code.
Mar 28, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
1,124 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
