Question about Microwave Ovens
Westinghouse 558 electric over, how do i set the time so that the oven will work, moving into new house and no manual available
3 Suggested Answers
  • 155 Answers
SOURCE: just moved into a new house, has a westinghouse
you have to reset oven to manual by holding down 2 buttons then reset time your user manual should explain the process if you still have it if not keep trying
Posted on Feb 01, 2010
  • 1833 Answers
SOURCE: moved into house with westinghouse
This problem can arise due to the following
1. The is not powered on
2. Gas valve is not turned on (for gas oven)
3. Clock is not set.
I am assuming that the first 2 problems are resolve by you already. For clock setting you have follow the following steps.
1. Press the "mode" button until the "clock" indicator begins flashing.
2. Press the - or + buttons to change the time. 5 seconds after the last change, the "clock" indicator will disappear, confirming the time has been set.
I am sure the problem is in clock setting. Please refer to your user manual for other clock settings. Note that without setting the clock properly the oven will not start.
Posted on Aug 12, 2011
Touchpad on Westinghouse Microwave not working
From the description the whole keypad control board will need to be replaced, but keep in the part is more expensive than some brand new microwave oven.
Apr 20, 2012 | Westinghouse WST3504 Microwave Oven
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Purchased G.e. JES2051 microwave May 3rd, 2010. When I press start, it trips the ciracuit breaker every time. I had the braekr changed and it would still trip the breaker--every time. I have moved the...
Verify the manual or the sticker in the back, check for the electrical rating (AMPERS) 15 for a house appliance and 20 for commercial type oven, if your electric system meets the ratings then (if it is still under warranty), go to the store have it replaced, with all the tests you did, it is definitely defective.
Jan 12, 2011 | GE JES2051 Microwave Oven
Just moved into a new house, has a westinghouse electric oven, everything seems to be working but the oven itself. The timer is flashing and reads Auto down the side, pressing butting doesn't seem to help....
Feb 01, 2010 | Microwave Ovens
Need owners manual for Westinghouse microwave Mod.#WST3507SS.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Mar 02, 2009 | Westinghouse WST3504 Microwave Oven
Westinghouse WST3501 Microwave
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Aug 30, 2008 | Westinghouse WST3501 Microwave Oven
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Ge single oven
Did the technician measure the power line voltage? Do you have or have you had trouble with any other electrical items in the home? This could indicate a defect in the design or manufacturing, but most manufacturers are reluctant to admit it easily, since the costs of a reall can be pretty steep. You might want to call GE Customer Relations at 1-800-386-1215 (8-6 ET). Feel free to follow up with more details if we can help further. We appreciate your thoughtful ratings to our reply.
Aug 16, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
