Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, thanks barry smith
    Sergeant:
    Champion:
  • 220 Answers
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Posted on Mar 11, 2011
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
It does not opens says corrupt file
click on start->control panel->add/remove programs and remove yahoo messenger from the program
then install the yahoo messenger again
you can download the setup file from
http://in.messenger.yahoo.com/download/
Jul 27, 2010 | Yahoo Messenger
How do I uninstall yahoo messenger? I get no install.log file when I try.
Try re-installing it. then go to Control Panel => Add & Remove Program, scroll to nearly the bottom, there you will find Yahoo Messenger. Then you can uninstall it.
Thanks
Oct 24, 2009 | Yahoo Messenger
I want to uninstall messenger but intall.log.file popsup what2do
TRY GOING TO THE START MENU THEN CONTROL PANEL THEN ADD/REMOVE PROGRAMS SCROLL DOWN UNTIL YOU SEE YAHOO MESSENGER THEN CLICK ON THE REMOVE BUTTON. I THINK THIS SHOULD HELP YOU OUT .
Jan 06, 2009 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
Incorrect line parameters winos installer v 2.00.26.00.0
Dec 09, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo messenger 81003005 problem
To get away from errors you need to use YM8.1
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
Nov 28, 2008 | Yahoo Messenger
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
