Question about Lasko Ceramic Heater
I just bought the Lasko model number 6221 and there are no instructions. Should I take it back (there were not anymore of this model) or can I get instructions?
    Brigadier General:
  • 4,736 Answers
Here's a link to a Lasko page where you can download an Owners Manual. Unfortunately, the link from that page no longer works, However, there is a 800 number for customer service. They can provide you with the Owners Manual. Hope this helped you.
Posted on Mar 11, 2011
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
I can't see the green temperature numbers anymore. Can that be fixed?
Not economically viable to repair, however the temperature is not what matters, comfort is, and if you set it midway and like that mark it and leave it where it works ok for you. Thermostats are not always jiving with thermometers .
Oct 31, 2012 | Lasko 758000 Ceramic Heater
WHERE CAN I GET A MANUAL FOR A LASKO CERAMIC HEATER MODEL 6221?
you can try to go to manuals.com and input the info, some one there should help you.
Mar 27, 2011 | Lasko Heating & Cooling
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
Where can i buy the crib to toddler bed conversion kit for model # 4341-1 ??? originally bought from burlington coat factory i believe.
Call Delta's Parentlink customer service number.
Hours of Operation Monday through Friday
8 a.m. to 8 p.m. (Eastern Standard Time)
1-800-377-3777 extension 6221, or
212-645-9033
Feb 24, 2011 | Delta Luv Lauren 4341
My lasko 5160 is flashing 88 with some other lights on,what do i do
At least for the Model 5165, the "88" means there is a circuit error -- probably applies to other models as well. First, call Lasko Customer Service 1-800-233-0268 (M-F, 8AM-5PM, EST). Have your receipt ready. Lasko will ask for a engraved number at the bottom of the heater, may have to look a few times to see it, normally about the serial number. Hope this helps!
Nov 16, 2010 | Lasko Heating & Cooling
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Nov 30, 2008 | Lasko Ceramic Heater
Lasko  Ceramic Heater Logo
218 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
