I am trying to get into the serviceman mode on my Panasonic PT-47WX54J. i am stuck at the part where you have to push the action and volume down buttons to get into the mode but it won't budge!!
    President:
  • 1,623 Answers
Are you pressing the buttons on the tv or on the remote?
Posted on Mar 11, 2011
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
I have numbers and lettters that come up on the top left of my screen. is there anyway to get rid of them?
Most likely the TV is in the service mode. On the front of the TV while it is on press on the POWER and ACTION buttons at the same time and hold them down until the set resets itself and comes up with a service check screen. You can then power the set off then tuen it on again and the serviceman mode will be exited.
Nov 06, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Serviceman mode for sub brightness (D02) adjustment PT-53WX42F The default setting is too dark. Need to increase but I cannot find where to change the Sub Brightness adjustment setting.
Remote Method
  • In SET-UP icon, set antenna to CABLE
  • In TIMER icon, set sleep timer to 30
  • Exit menus and tune to channel 124
  • Adjust volume to 0
  • Press volume down (VD) on control panel and red 'CHK' will appear in the upper left corner
  • To toggle between Serviceman and Aging Modes press Action and VD on the control panel
Jun 16, 2009 | Panasonic Televison & Video
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Though i answered this exact question tonight, but maby it didnt post, sorry...heres the instructions.
To enter the service menu follow the directions below:
1) Go into the menu and select cable mode
2) Set sleep timer to 30
3) Exit menu and change chanel to 124
4) press and hold volume down button ON THE FRONT OF THE TV
5) A red "chk" should appear in the top right coner
Once you have the red CHK i think you press action to get the menu up, then chose convergence.
RTUNE- changes colors
MUTE-makes the cursor blink and not blink (when its blinking you can move it from point to point, when it stops blinking you can adjust that point)
"7" - saves the changes you have made
When you are done to exit the service menu follow the directions below:
Press ACTION and POWER buttons together on the FRONT of the set
the tv should the reset itself and turn itself off and back on.
Also if you have a convergence problem and have not repaired the circuit then going into this menu and trying to do adjustments can cause major problems in the dcu so if you have not repaired the circuit DO NOT go into this mode. you must first fix the circuit, and if you dont know how to fix it then you should call a repair man. You can cause major problems in the menu that are not fixable once they have been done.
Let me know if you need more info!
Sep 25, 2008 | Televison & Video
Did you do a repair on the convergence circuit? If so it would be ok to do an adjustment in the service menue. But if you have a problem in the conergence circuit and you dont repair it first, making adjustments in the service menue can do damage to the DCU and cause you major problem in the future. If you have already repaired the convergence circuit then let me know and i will get you the codes.
Tim nolan
experttv@comcast.net
Sep 24, 2008 | Panasonic PT-47X54 47" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
How do you exit service mode?
PANASONIC: Panasonic TV's after 1996 can be set to "Serviceman Mode" with the following remote control sequence: First, select the SET-UP icon and select CABLE mode. Then, select the TIMER icon and set the SLEEP timer for 30 minutes. Next, press the ACTION button twice to get out of the menus. Now, change to channel 124. Then, adjust the volume to minimum (0). You're almost there - Hit the VOL down button on the TV itself (not on the remote) and a red "CHK" should appear in the upper corner. Now, if you press the ACTION and VOLUME DOWN buttons (again, on the TV, not the remote) you will toggle between AGING and SERVICEMAN modes. Select Serviceman mode. The POWER button on the remote control will select one of the five Serviceman Adjustment modes. The modes are: B - Serviceman VCJ SUB Adjustments. These include sub-tint, sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,audio and video adjustment, and vertical size. C - Serviceman VCJ Cut-off adjustments. These include Red, Green and Blue cut-off, red and blue drive, automatic fine tuning(AFT), RF AGC (RF gain control), horizontal center, beam limit,etc. S - Serviceman Options Adjustments. These involce the PIP and clock. M - Serviceman MTS (Stereo/SAP) adjustments. CHK - the mode you first entered. Normal picture and sound, lets you check things over and still have a hotkey into the service menu. There is one more adjustment that isn't in the five modes, it's global. When in either the yellow or red CHK mode, you can press RECALL on the remote control to enter the purity firld check mode. This lets you select a pure white, red, green, or blue screen. A good thing to walk away from if you just want to temporarily freak out the floor manager, but it will be fixed as soon as the TV is turned off. To get out of Serviceman mode, press ACTION and POWER on the remote simultaneously for at least 2 seconds. The TV will momentarily shut off and then comes back on. If this does not help you will most likely need to get the service manual as you should always have that anyway before ever attempting any serve mode adustments. Also do not forget to ALWAYS write down all of the values that you change incase a problem arises. Good Luck
Mar 17, 2007 | Panasonic CT-27SF25 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
