Question about Dell SK-8115 Keyboard
I can no longer access the @ key, i get " instead
  • 3 Answers
SOURCE: 1.When I try to type @ symbol by pressing th ****
It sounds like you have another keyboard layout set as your default.
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English-US is selected as the Default Input Language.
If another keyboard layout is listed below and you don't need it there, you can remove it to make sure it doesn't switch itself again.
Note: this is for XP. Vista will be similar, but I don't have a vista machine so I can't tell you exactly what the options will be called.
I hope this helps. Good Luck.
Posted on Jun 24, 2009
  • 86 Answers
SOURCE: Where can I find an explanation of how to use the
You could actually check from the dell support site for this...
http://support.dell.com/support/edocs/systems/ins8200/en/sm_en/index.htm
Posted on Jul 08, 2009
  • 70 Answers
SOURCE: certain keys are creating double letter combinations
i think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Posted on Sep 26, 2009
  • 415 Answers
SOURCE: The keys are not synchronised properly. The @ key
you are using a usa keyboard.
if you want to use the uk keyboard layout change the regional settings, go to languages and there is an option to change the keyboard.
uk keyboard will print " when pressing shift+2
Posted on Jan 12, 2010
  • 2666 Answers
SOURCE: Some of the keys not working such as the pound
Your PC Language settings are incorrect
How to change keyboard language in Windows
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Posted on Jul 02, 2010
How to use the this " @ " key on dell vostro 1015 laptop ?
This can be a little tricky. You will need to hold down your "Shift" key located below your "Enter" key and then while holding that key down press the number 2 above your "Q" and "W" keys. This handy little trick can be used to access any of the symbols located on each of the number keys.
Sep 15, 2011 | Dell Vostro 1015 Laptop
How to key @ on the keyboard, only able to get " instead of @
Press the shift button while pressing the number 2 on the top row.
Mar 12, 2011 | HP CPQ175KB Keyboard
Standard deviation
Here it is.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Oct 07, 2010 | Casio fx-300ES Calculator
How to calculate standard deviation
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
How do i get a decimal on division instead of a fraction? in example when divide 100 by 3 it gives 100/3 instead 33.3
  1. If a fraction (or a radical) is already displayed press the [S<=>D] key to convert it into a decimal number.
  2. If you are entering an expression and want its result displayed as a decimal number, press the [SHIFT][=] key sequence instead of just [=].
  3. More permanent solution: If you do not want fractions nor radicals, configure the Input/Output to be LineIO. To do that, press [SHIFT][MODE] to access the (SETUP) then select the option [2:LineIO]
Jun 01, 2010 | Casio fx-300ES Calculator
How to calculate the standard deviaition on the casio fx115es
Apr 05, 2010 | Casio FX-115ES Scientific Calculator
I love my keyboard but when I press apostrophe quotes they don't appear unless I press the button twice and then I get double and have to backspace to get single quotations again.
Hi
I beleave that is how that button is supposed to work, on all the keyboards i've ever used the same thing has happened, instead I press on the " key instead of the ¨. I suppose the " is what your looking for instead of the ¨.
I'd guess your pressing on the wrong button, find the key that does " " " ", you may use SHIFT together with another key to get " to come out.
On my Finnish keyboard its SHIFT + 2 .. = "
Dec 22, 2009 | Microsoft Wireless Optical Desktop 1000...
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Keypad
see on your keyboard's keys, the symbols which is above is to be pressed by holding down the shift. As ! is above 1 so for ! you have to press Shift + 1, same as @ is above 2 show for @ you have to press Shift + 2, simalarly # is above three so for # you have to press Shift + 3........... is it clear.....then... :)) ... otherwise Ask me again.
Iqbal
Apr 05, 2008 | Acer Aspire 5102WLMi Notebook
Dell SK-8115 Keyboard Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
