My akai MG-14-D will not play,rewind,fast forward or eject! also the LED's peak when powered up and will not stop peaking, until powered down?
I had the same problem and fixed it by replacing one of the voltage-regulators 7805. It's located at the back of the powersupply-card.
Posted on Sep 01, 2009
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
6313cg - stuck tape
If the eject mechanism is belt driven, check to see that the belt not slipping or off the pulley. If gear driven check to see if the motor that powers the eject cycle is receiving power when called for.
Feb 16, 2014 | Sylvania 6313CG 13-Inch TV VCR Combo
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Rewind and fast forward
Put the cd in when it loads and display the disc time, you can then spin the round wheels forward or backwards to the place on the song that you're playing, this only work when the song is paused or stopped. If the disc is playing the wheels are only used to slow down or speed up the song.
J Lofton(2Housepeople)
Oct 17, 2008 | Gem Sound CDM-150 Mixer
BUTTONS ARE STICKING
Switch block assy needs replacement, the one where the play. rew, stop button controls, Because its always moving during tape eject, the flexible wire in it is already snapped. tnx
May 13, 2007 | Sony Handycam CCD-TRV37 Camcorder
Playback problems
try to open the cover and clean the video head with a clean piece of paper dampened with a little alcohol. place the paper on the head using your finger and slowly moved the drum. donot move the paper up or down just move the drum slowly. the symptom also indicate that the head had reach its peak point and need to be replace with a new one. good luck!
Jan 30, 2007 | Sony Hi8 CCD-TRV138 Camcorder
390 people viewed this question
 Grubhead
Grubhead
