Question about Alpine MRP-M500 Car Audio Amplifier
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be causing these problems. The set up worked fine for 2 1/2 months. Thank you for any help.
    Novelist:
  • 147 Answers
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Posted on Mar 12, 2011
CDE-9845 power up my MRP-M500 amp but subs wont work?
Have you checked the subs? And tested the RCA cables?
Mar 20, 2012 | Alpine CDE-9845 CD Player
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Alpine MRP-M500 Car Audio Amplifier Logo
274 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
