Question about Amana Refrigerators
Amana refrigerator model # TN21V2W Need a Manual to show how to switch doors from left to right.
larryyb
  • 291 Answers
SOURCE: Refrigerator door not closing all the way
the pressure inside the box is pussing the other door open and what you need to do is tilt your refrig back until the door will close by itself and that will be as far as you need to go back with it ,,,, it's normal for it to happen and a frig should always have a little tilt / larryyb
Posted on Nov 28, 2008
  • 118 Answers
SOURCE: amana refrigerator door gasket Model #sr22gl
You may wish to contact the folks at RepairClinic.com. They have a large selection or repair and replacement parts at a fair cost. You'll need to know your brand name, model #, serial #, and the approximate age of the appliance.
Posted on Jul 25, 2009
  • 4 Answers
SOURCE: French door refrig..right door pops open when left door is closed
remove the door and check the closer inside the door @ the bottom . it is a cam that helps close the door and it is probably broken part # 67002732. this was the problem with my maytag fridge-- 3 visits from A& E could not solve the problem. hope this helps
Posted on Aug 22, 2009
  • 10 Answers
SOURCE: HELLO, WE HAVE A AMANA REFRIGERATOR, FREEZER ON
You need to check level of the fridge. Should be level side to side with a slight front to rear . (Fridge tipping back slightly)
Posted on Feb 05, 2010
Testimonial: "SOLUTION #1 SEEMED VERY REASONABLE. I AM GOING TO GET MY LEVEL NOW AND CHECK THE RELATIONSHIP TO THE FLOOR THE FRIG. IS SITTING ON."
  • 52 Answers
SOURCE: OUR AMANA TR25VW REFRIGERATOR W/
Check with your owners manual, that will show you how to re-align the doors. Or, worse case scenario, the internal rail is bent and needs to be replaced. Do a visual check on that.
Posted on Feb 06, 2010
Amana tn21v2w
TN21V2W
21 cubic feet
W=32 5/8
D=33 1/8
H=67 3/8
Sep 20, 2013 | Refrigerators
My Amano top/bottom fridge freezer has no temperature in the fridge- my wife taped the light shut which left the control panel showing nothing but now the fridge works- my tech nician said I need to change...
A light switch failure can leave the light on even with the door closed, raising the temp. to over 40 degrees. Firstly, make sure doors are not sagging creating a switch activation with the door closed. If that checks good, replace the door switch.
Oct 07, 2017 | Amana ABB1927DE Bottom Freezer...
How do i reverse the refrigerator door of an amana arb2217csl
you canot reverse the handles on this model. There are no predrilled holes or covering plugs on the opposite side. The model number ends in an "l" signifying left hinges. The companion model ends in an "r" with hinges on the right. These fridges were designed so you could purchase them as a pair seting them side by side.
Oct 09, 2010 | Amana ARB2217CSL Bottom Freezer...
OUR AMANA TR25VW REFRIGERATOR W/ TOP FREEZER, RUBS AS YOU CLOSE THE DOOR IN THE LEFT LOWER CORNER.
Feb 04, 2010 | Refrigerators
Freezer handle has de-attached from door on right side - can it be repaired? I cannot see how you could get at the bracket from inside the freezer door.
I checked the owners manual - found that two small screws holding the bracket on came loose - reattached the screws, then de-attached the handel from left side so entire handle was off. Then slid handle on both brackets left to right until it clicked on.
Nov 26, 2009 | Amana ABB1927DE Bottom Freezer...
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
66 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
