Question about Jet 3 Ultra Power Chair
Where should the output from the charger be read?
  • 692 Answers
Karrie if the chair has an on-board charger you can read the charger voltage at the charger port located under the front of the joystick. Set a meter to 200vdc and plug the leads into the two outter ports under the joystick Plug the charger into the wall socket and you should be able to read the charge voltage it should be 27-30 volts. If you have a off-board charger you will have to read the voltage at the batteries with the charger plugged into the the charger port under the joystick. Hope this helps
Posted on Mar 12, 2011
My cordless phone wont charge
Take out the plug of charger adapter and hook a multimeter to check if your charger is working or not. Output voltage is mostly mentioned on the charger and it should tally with the reading on multimeter.
May 14, 2013 | Motorola Mobility MD4260-2 Twin Cordless...
Battery charging
Check your charger to make sure it is the right one for your laptop. If it is then test it's output to make sure it is producing the correct voltage and amperage. You can read the label on the charger to find out what it should be. Then a simple test with a multimeter will tell you what you want to know. If that is all good, check the contacts where the battery plugs in. Are they in good shape? Not bent or broken. Clean them with a pencil eraser so they are shiny. Now, disconnect the charger and plug in your battery. Do you have an indicator of power? Will your laptop boot? If not, use the multimeter to test the output of the battery. It should read the same output voltage as the charger.
Jun 04, 2012 | Toshiba Satellite A665-S6086 Laptop
How do u know if your ryobi charger is burnt out
Checked the output supply of the charger using tester, in using tester you must need to know the output supply if it is in dc(direct current) or AC(alternating current), then select it from the selector of the tester if there is a reading then that good,make sure to know the supply of your ryobi charger by checking it from the specs of charger itself.. If the reading is accurate then the charger is good if not then the charger is defective then replace a new one. Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up I really appreciate what Ratings you have given to me. Thanks a lot and God Bless.
Jun 21, 2011 | Drills
I have a MPV4 Hovaround Electric WheelChair Power charger does not charge. What is wrong?
weel two thinga could be the cause bad batteries or a bad charger, If you have a meter you can set it to 200 vdc and plug the leads into the 2 outer holes of the charger port located on the joystick it will read your battery voltage and should not be below 16 volts. with the same meter have someone hold the charger plug and with it on read the output of the charger across the two outter pins careful not to touch the center pin with the leads it should read 27-30 volts if it is working Hope this helps
Feb 26, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Chair dont take a charge
Get new batteries If your batteries are 2-3 years old its time for new ones. You can check the output of the charger by using a digital voltmeter Set the meter to 200 vdc and plug it into the two outter holes of the charger port with the charger plugged in you should read 27-30 volts. and with the charger unpluged you can aslo read the voltage of your batteries. fully charged they should read 25 -27 volts. If when charging you don't read 27-30 volts then the charger isn't working and you can get an offboard charger cheaper than the onboard just charge thru the charger port on the joystick. Hope this helps
Feb 03, 2011 | Jet 3 Ultra Power Chair
How do you test output voltage for a NDS charger?
If you have a multimeter, simply use the positive and negative probe to touch the output of the charger, you should be able to read ~5V.
Jan 06, 2011 | Nintendo DS Lite Console
Xantrex Inverter/Charger has no AC output
HI
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Want to buy a charger for Shark Cordless Sweeper
If you have the old charger, look at the pin and read the output. Many electronics clearance stores sell a generic charger which will match the output in volts and amps as long as you find the identical pin configuration. Volts may exceed the original battery rating by 20%, amps can as well. IE I have a 9.6 volt charger on my 7.2 volt battery pack.
Sep 06, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
I have a scooter and it was working perfectly but now i plug in the charger and doesen´t charge what should i do?
Assuming you didn't get the PC board mounted inside the top of the tiller assembly wet, or the power controller located under the shroud, then you likely either have one or two of the batteries that are bad, or a bad charger. You will need a voltage tester that you can pick up cheap for about $6.00. Set to the DV voltage setting in the 50-100 volt scale. Remove the seat and the shroud and test the voltage at each battery. If good, they should read about 12.25 volts or more, not higher than 14. If one is normal and the other lower, say 10 Volts, that low one is bad, but you should probably replace both with fresh gel batteries, fully charge before using. If both batteries are about 12 VDC, then plug in the charger to the chair as usual, and take another voltage test on each battery. The voltage should read higher now that the charger is on. If they aren't, then your charger has no output. Some chargers you can test output voltage on without them plugged in by testing across the two horizontal pins on the 3-pin connector that you plug into the chair. The output voltage should be about 26 volts. If it is 24 or less, you need a new charger. Good luck.
Jul 22, 2009 | Pride Mobility Products Health & Beauty
Jet 3 Ultra Power Chair Logo
88 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
