Question about Electric Strider Mini 4 Wheel Mobility Scooter Cherry
Hi I have a Strider mini4 runs ok but speed seems to vary and battery charge display goes from charged to flat .the needle moves backwards and forwards whilst driving! Had new batteries could it be the wig wag or speed pot?
    New Friend:
  • 4 Answers
I'm having the same issue as you are :)
Myself I would get the speed pot and wig wag replaced at the same time, and see if that helps. I find the needle battery meters more accurate than modern LED ones too...
Posted on Apr 10, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
God i love being here to help,i have nearly died 7 times to date,but never been happier,you gotta download this as a PDF File & print n save in a polythene folder for future:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 And do that at:www.alldatasheet.com And guess what its a free site.And it is what it says [ALL DATA ON ANYTHING EVER] Some people love to win the lottery yes lovely,but if i could choose between the lottery or helping you people,it would be you,thats the truth,and i do it for free,it would be great to hear a thanks,but if you too ill,no prob im disabled myself Colin.
Posted on Mar 12, 2011
Batteries for strider full, but wont move brake appears to be on.
Hi how did u test the batteries.the only accurate way to test them is to use a BATTERY load tester ...u can buy them on E/BAY.APROX COST $35::.cheers
Jul 05, 2016 | Electric Strider Midi 4 Wheel Mobility...
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
98 crown vic charge light goes on and needle goes to full charge when excelerating?
Sounds like the voltage regulator has failed.
Check voltage at the battery with the engine at idle and again with the engine at cruise speed. Voltage should be around 13 volts at idle and 14.5 volts at cruise speed.
Aug 06, 2012 | 1998 Ford Crown Victoria
Ihave a strider st4 and the power gauge goes down fster than any other scooters
hi, OK first check the charger, is it charging correctly please confirm this if possible by borrowing a charger, check the charging port, it is a loose fitting , do you always get a green light on the charger ?, if not check the connection at the charging port.
if after use say greater than 2 miles , the batteries charge up within a couple of hours, that points to your batteries losing the ability to take a charge, now first check the terminal connections to the batteries, are they clean and tight.
Check the brake mounted on the side of the motor, can you hear a click when powering backwards or forward , it may be advisable to get the wheels off the ground, please take care when doing this.
If the brake has become lazy it may not be releasing 100% , moving the wheels around when slight , (just so yo can hear the click, it may be very faint), power applied will test this, again please take care when doing this test
OK so the batteries are charging up, then sadly 95% sure it your batteries, that need replacing. the other 5% being a faulty controller, dodgy motor, but this is very rare.
Please leave feedback if the suggestions help.
Regards GeWiz.
Feb 02, 2011 | Electric Mobility 4 Wheel Heavy Duty...
Hi the battery is flat on my speed triple its
hi might be able to help,if the bike has been stood for a while and the battery is flat,you will need to either slow charge the battery(if it will accept a charge) or replace it,jumping the battery will only give the battery a surface charge and will not be adequate to run all of your electronics effectively,this may be why the engine management light is staying in,hope this helps..cheers
Feb 20, 2010 | 2002 Triumph Speed triple
AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Jan 11, 2010 | Pride Mobility Products Go-Go Elite...
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Electric Strider Mini 4 Wheel Mobility Scooter Cherry Logo
187 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
