Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Low vacuum will not pick much of anything - Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
Not picking anything up off the carpet
You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Feb 16, 2010 | Vacuums
My riccar vacuum does not pick up anything
Check the belt and then the tube on the side of the vacuum that runs from the bottom to up the side to the bag. If they belt is broken the vacuum will not pick anything up. If that tube is clogged up with dirt that will keep the vacuum from picking up as well.
Oct 20, 2009 | Riccar Vacuums
IRobot stopped picking up larger bits from the carpet. It picks up the dust, but anything larger, it leaves behind. Have changed the filter/brushes. Is there anything else I need to do
Its sounds like the brushes aren't turning. Pull the vacuum and bin off the back and start it and look to see if the brushes are turning.
Sep 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Have eureka 9734 replaced belt, put back together,brush rotates well but vacuum is not picking up anything, no suction.
It sounds like the machine is clogged. Check the port behind the belt and any and all hoses for obstructions and remove.
Apr 13, 2009 | Vacuums
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
