Question about Electrolux Epic 3500 Vacuum
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
  • 694 Answers
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Posted on Mar 12, 2011
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
How to change vacuum belt on a electrolux upright
ok,there are a number of screws under the power head unit.Remove them and gently pull off the top.gently remove brush,put new belt on the motor shaft first then put brush nack in position with belt on...Do not tighten up,there should be a little play in the belt.Simply put cover back on ..
Sep 05, 2014 | Electrolux Vacuums
How to fix expelling dirt from electrolux versatility?
sounds like the vacuum is blocked.Turn vac on its back and check the area where the dirt goes in,there is probably something stuck in there....
Jun 23, 2014 | Electrolux EL8502 Versatility Bagless...
I cannot find a replacement belt for my Electrolux versatility HEPA bagless upright vacuum cleaner. Model# EL8505B
You can try to get a belt directly from Electrolux or maybe a local vacuum cleaner repair shop
Aug 14, 2013 | Electrolux Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Vacuums Logo
318 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
