Question about Car Audio & Video
Wired jvc stero in a 2005 jeep cherokee, push power button nothing, push cd eject button & lights up plus accepts a cd then shuts off? what can i do?
    Sniper:
  • 58 Answers
First check the fuses, if the fuses seem to be fine then do the following steps.
Try doing everything you explained with the ignition key in the off position. If you can still do all of that with the ignition off, then you probably have a bad connection on the RED wire. If you can't do that stuff with the ignition off, then you may have a bad connection on the YELLOW wire. Also you might as well check the BLACK wire (ground).
If the fuses were good and all of the wires had a good connection you may want to use a tester to check and make sure the wires don't have a short somewhere.
If you checked everything and you still have the same problem, then my guess would be that something has went out internally on the stereo.
Hope this helps.
Posted on Mar 14, 2011
My car radio jvc won't eject my cd? an need to kow how to?
this is a common problem with this model radio. if it wont eject by pushing the eject button. you can do a hard reset by holdin the SEL button & the POWER button at the same time until the until ejects your disk. OR pushing the SEL button first, then the POWER and holding both until it resets.
hope this helps
Sep 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Cd stuck in cd changer
You could take the radio out and take it apart, but you would still have an $1800 CD. Suggest forgetting about the CD, and getting an aftermarket installed for much less.
Mar 07, 2009 | 2005 Suzuki Aerio SX
Eject navigation disk in 2005 Jeep Grand Cherokee
Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
Feb 10, 2009 | 2005 Jeep Grand Cherokee
2008 Durango Limited
The eject button is the load button on our 2005, maybe the same for you. Just hold it in for a few seconds and it should spit out your cd. You should be able to lightly put the cd up to the insert space and it should take your cd. If your cd player holds multiple cds then perhaps there are some in there that have not been ejected. Hope this works for you.
Oct 27, 2008 | JVC KD-AVX1 Car DVD Player
JVC KD-G200 cd player
I would suggest checking the accessory (red wire), the yellow is a constant feed from the battery, which will allow the clock to be displayed no matter what. The accessory wire is what is used to turn on the cd player. You may need to restrip the red wire and check the lead going to the red wire with a test light to make sure it is getting a voltage light.
Mar 03, 2008 | JVC KD-G200 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
