Question about Bissell 3750 Lift Off Bagless Upright Vacuum
I was lifting off the canister, and now there is a connector sticking up from the base. It looks like a phone jack connector. I can't reattach it. It's right in the center of the bottom of the cannister. It is the top of a half-circle plug that is in the center of the base. Is there a trick to reattaching it? Help?
    Sergeant:
    Champion:
  • 250 Answers
If the connector does not move when you gently push or pull it when you slide the canister back on the vacume it should go in place. If it is on a short piece of wire you have to gently fit it in to the hole on the other part of the vacume
Posted on Mar 12, 2011
I cant get my Dyson canister to reattach correctly.
Hi Gayla, it's Jack at Dyson.
I'm sorry to hear you're having difficulty replacing your DC28's clear bin and cyclone. They should lift away from the machine when you push the red release catch, and should reattach in the same way without any issues.
From what you've described it sounds as if something is out of place. You may want to remove and replace the washable HEPA post-filter as shown in the video below - if the clear post-filter cover isn't fitted correctly this could prevent the bin from sitting correctly on the vacuum. Make sure all the black rubber seals are in position, and that the bin base is closed all the way around. It's also a good idea to check the red release catch for any damage.
If you continue to have difficulties you're welcome to get in touch for some additional assistance. You can reach us by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Feb 26, 2015 | Dyson DC28 Animal Vacuum
Dyson canister won't fit snugly
I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
Best wishes,
Jessica
Jun 22, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Canister will not open on Dyson Dc 07 animal
Sorry to hear you're having difficulties with your DC07 Animal. If the bin base won't open when you pull the trigger, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 26, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The canister will not snap back onto the front of the vacuum.
Sorry to hear you're having difficulties with your DC14. If the canister won't reattach to the vacuum, you might want to check you have it assembled correctly - you can find out how to do this in the user guide supplied with your cleaner. In case you don't have this to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
If you're certain the bin is assembled correctly and it still won't attach to the cleaner, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 03, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bottom of canistter has come apart from the canister how do you reattach the bottom
Sorry to hear about the problem with your DC17. If you look at the front of the bin base, you should see two tabs, which correspond with the indentation on the front of the bin body. You should be able to line the tabs on the base up with the notch on the bin body, and gently but firmly clip the two pieces back together.
However, if you have difficulty doing this, or if the tabs have broken off, it's probably best if you get in touch with us so one of our experts can provide further assistance.You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com.
Kind regards,
Jack
Jul 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can't detach vacumn hose from hose grip base to clean with canister.
turn it 90 degrees to release it , if you look you will see ( unless its reallly dusty ) 2 tabs that are inside the hose attachment itself
May 08, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
Kenmore PowerMate cannister: Reattach cannister floor piece.
You need to open the head by gently squeezing the light cover housing and lifting it off. There will be two screws underneath and once removed the lid will lift off and reveal the area where the pedal installs.
Sep 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
Help
hello jane just a brief message if you look on tis board at a similar problem i have just replied to about canister cover lifting off ? this may also be the same problem as the fixit solve i have suggested ? about blockage of filter please read it and will explain fault /remedy best wishes from uk
Oct 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
48 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
