Question about Canon PowerShot S2 IS Digital Camera
When I turn on the camera the screen is totally black but if I look in the viewfinder there is a small white rectangle in the center of a black screen and 12X on top. I want to know what I should do to change the settings so I can see what I am about to photograph on the screen. I also am unable to snap a photo.
  • Canon Master
  • 3,083 Answers
When you turn on the camera, it should initialize, not show a dark screen and these messages. The zoom on the camera coul be stuck, or there could be other problems going on with the lens assembly.
The following web blog details things you can try to fix this problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.htmll
If nothing helps, take the camera in to a local repair shop for an estimate, or contact Canon:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Posted on Mar 12, 2011
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Mar 06, 2010 | Televison & Video
My camera got wet and now the viewfinder and the pictures turn out black.
If it just got wet slightly, you can use a canned air to blow dry the camera. If got totally wet, it will be most advised to take your camera to an authorized service center with or without warranty. There still maybe some wet parts left inside so using the camera further might result to further damage.
Sep 21, 2009 | Sony Cameras
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Image through Nokia F80 viewfinder dark and cloudy
Please also ignore this answer, (see askers comment above). I've only posted it so that this question doesn't continue to appear as an unanswered one.
If anyone else has this problem please go to
http://www.fixya.com/support/t2637498-image_nikon_f80_dark_cloudy
for an answer.
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Viewfinder screen and viewfinder are black and lens is off
Make sure the selector switch is turned to record (the center position) and camcorder is turned on. Make sure the viewfinder is pulled out fully when you look in it. If that doesn't work try resetting the camcorder. Open the LCD and there is a small hole near the play button, gently push a paper clip in the hole all the way and press the power on button.
Mar 24, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Panasonic Lumix - LCD & viewfinder WHITE
my camera just did that to me yesterday..i had t for like a week.. did u have a warranty on it or something like that?? i have to take mine back to the place were i got it and go talk to them about it.. my screen is like shot or something..
Feb 21, 2008 | Cameras
Camera repair
Time for a new Camera. It is about 150.00 to replace the LCD. it is cheaper to replace it unless you can just use the viewfinder alone!!
Nov 13, 2007 | Kodak EasyShare Z612 Digital Camera
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sony cybershot dscp73 view screen
Good Day, LCD display is defective, pls contact nearest service center, no longer user serviceable, still u can use it using optical viewfinder, but you can no longer change settings, cause infos are displayed on the LCD screen. Thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
13 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
