Question about Maxtor Hard Drive
Maxtor diagnostic utility reports error code dea39C79 on a 160 GB Maxtor diamond plus 9 ATA drive. What does this mean please. regards Eric Rogers
  • parker210 Mar 14, 2011
    The utility just reports the code stated and tells me that the drive is failing, which I am not suprised at since it is dated 2003 and has seen regular light use since.
    Computer symptoms are funny ticking noises from the drive, computer running slow and eventually freezing, and frequent need for checkdisk.
    Scholar:
  • 115 Answers
Hello
Please try visit this website http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=185263&NewLang=en&Hilite=
Posted on Mar 11, 2011
  • Maxtor Master
  • 27,725 Answers
Im not familiar with this type of error you might just try the to troubleshoot the problem until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
hope this help dont forget to vote
  • Brian Sullivan
    Brian Sullivan Mar 11, 2011
    if its the d3d9.dll file belongs to the DirectX 9 software and its main function is to add DirectX functionality to Windows games and other multimedia applications.
    D3d9.dll Errors
    Many of the d3d9.dll errors occur when you have older version of DirectX on your PC. For instance, you may receive d3d9.dll errors, similar to the ones listed below in case you try to run a game that is specifically written for DirectX 9 on a PC that uses DirectX 8 or some other older version.
    hope this helps you
  • Brian Sullivan
    Brian Sullivan Mar 15, 2011
    the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free up the reader arm
    once you have your computer running
    click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input will damage your computer
    hope this helps
Reboot while Formating Hard disk Maxtor diamondmax plus 9 120 gb ata/133 hdd Now my hard disk says it's damaged when i want to format it, can you sugges me some software to repair it ?
you could runthe chkdsk utility click start tpe cmd you are now in dos then type chkdsk/f/r to scan for and attemp to repair any bad files and bad sectors on your hard drive this will schedule to happen on restart of your computer another way of running the chkdsk utility click start click to open you should see your drive C: right click on select tools check now you will see two boxes tick in both again this will schedule to happen on restart if this is your primary hard drive with your operating system on it
hope this helps you
Jul 24, 2011 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Maxtor hard drive diamondmax plus 9 ata
Usually the PIN settings are indicated on top of the drive. Have a good look at the sticker. Hope this helps.
Jul 17, 2010 | Maxtor Hard Drive
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Is the maxtor 6y120p0 a ata or sata format
Maxtor DiamondMax Plus 9 120GB 7200RPM IDE Ultra ATA-133 3.5-Inch Internal Hard Drive Mfr P/N 6Y120P0
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
Windows xp shows hard drive as 30g. I have diamond max plus 9 120gb model 6y120PO s/n y25W76E bios shows maxtor 6y120PO capacity 33821mb
It is probably partitioned. Right click on "my computer" select "Manage" and then look at the disk manager. You will find that the rest of the drive is there, but un partitioned and un formatted.
Jul 11, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Maxtor Diamondmax plus 9 HDD Error on boot up
Maxtor were taken over by seagate some time ago - try downloading and running the Seagate diagnostic tools "SeaTools"
http://www.seagate.com/gb/en/support/downloads/seatools
Jul 23, 2017 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
I HAVE A MAXTOR DIAMOND MAX PLUS 9 60GB ATA/133 HDD. I HAVE LOST HALF OF MY DRIVE CAPACITY. dANI115@COX.NET
try using a partitioning utility like gparted, pmagic, partition magic etc. this will tell you whether your drive is full, partitioned, how much is used and if the partition takes up the full disk. also, try doing scandisk on it to see if there are errors and to get the errors fixed
May 25, 2008 | Computers & Internet
Maxtor Hard Drive Logo
155 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
