Question about Olympus Stylus / mju 1050 SW Digital Camera
My shutter is not functioning. i can't literally take pictures. thank you. help!!!
  • 62 Answers
First I would try to reset the camera in settings menu. However, I would think this point more to the fact that the camera is defective and will need to be sent in for service.
Posted on Mar 12, 2011
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
Tried to take pictures of lightening last night and couldn't. My lens kept going in and out and wouldn't focus so wouldn't allow me to shoot. Then I kept getting a BUSY across the screen. ...
For this kind of pictures, Don't try to focus on a lightning, it is to quick and mabe the overall brightness is not enough for your camera to focus.
So you can try to focus on something at infinity, if you manage then, put your focus on manual before re focusing, this way you will be able to take as many pictures as you want.
You can also try to focus manually directly.
And for you information the best way to take a lightning picture is to put your camera in bulb mode, use a remote control, open the shutter and close it as soon as you'v seen a lightning.
Hope this helps.
and good shooting !
May 27, 2011 | Canon EOS 500D EOS Rebel T1i Digital...
While clicking pictures, the screen went black. If i click a picture, it takes black picture. I am able to see previously clicked pictures and all other functions work. Pls help.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
My camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
Jun 02, 2009 | Canon PowerShot A410 Digital Camera
Help me i have lines on my pictures and i dont know what to do!!!
Your shutter is not closing correctly. only solution is to strip it down and clean the shutter. The lines are due to over exposure. pictures in daylight will appear too bright. The video function should work ok as it does not use the shutter.
Apr 15, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Power Shot A75
Of course it does, it has full manual control (M), but may I suggest first trying "shutter priority" (Tv). This mode lets you set shutter speed up to 15 seconds, but it automatically sets the aperture to match the shutter speed that you set. Merely turn the mode dial to Tv, then use the right/left buttons to select the shutter speed.
Now before pressing the shutter button, may I also suggest that you use the camera's shutter delay timer to take the picture (this will eliminate any shake from you pressing the button). Just press the function button to bring up the menu. then find the timer setting (try 2 seconds).
Here's where you can download your camera's user manual if you want to read more on what your camera can do:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=9828#DownloadDetailAct
Jul 19, 2008 | Canon PowerShot A75 Digital Camera
Olympus Stylus / mju 1050 SW Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
