RCA entertainment series 42 in will not come on but power light blinks on & off.
  • Anonymous Nov 29, 2008
    I have the same issue with the 42 inch. My led blinks once and turns off. Now when I unplug the TV and plug it back in, I hear a loud screaching noise. I assume it's a goner.
  • 8,617 Answers
I will need the model number of your RCA and also how many times the led blinks. Please respond to this same post when replying
Posted on Aug 01, 2008
My rca entertainment series 32'' will not come on it has bern unplugged for a couple of weeks but before then it worked perfect, please help!!!!
a lot depends on the model number of the set===on the back can you read the model and chassis number?
Mar 13, 2012 | Televison & Video
My RCA L42WD22 flat screen will not power on after being turned off for an hour. When I tried to power it on the green light comes on, and I have a flash of a picture, then a black/blank screen & a...
Take the tv apart.The tv power supply board,that the board,have power a/c cord plug into it.That the power supply board,check component parts like capacitors,see if it leaking gases,these capacitors are dead.Capacitors they'll alway bulges up on it tops or puff up on it tops.Have tools like soldering iron and solders?Know basic electronic and soldering?Replaced these dead capacitors will get power to ur tv back.Or tries websites like Shopjkimmy.com to buy a whole refurbish power supply board for the replacement.
Jun 15, 2011 | RCA L42WD22 42 in. LCD Television
My sony tv has sound but no picture and red light keeps blinking
In accordance with facility to watch The Wire online,you can go through entertaining .Watch Online The Wire Season 4 Episode6 - Watch-Series watch online series The Wire season 4 episode 6,download full episodes for freeWatch The Wire Online - Full Episodes ofThe Wire & More TV Set in Baltimore, this show centers around thecity's inner-city drug scene. It starts as ... the Wire - Watch Full Episodes of TV Shows Onlinecility to watch The Wire online with blinkx Remote
Jun 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
May 21, 2010 | RCA L42WD22 42 in. LCD Television
Green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Nov 20, 2009 | RCA L42WD22 42 in. LCD Television
Rca 42 in lcd it shuts off 5 sec after being turned on
This could be a power supply problem, these tv's use a series of switching mode power supplies usually mounted in the same circuit board , the light flashing is an indicator that this is the problem, but these boards are expensive so you may want to get the tv looked at before anything else. You do not mention if the sound remains in your description of the symptom, but just in case it does then a back light inverter could be at fault. hope this helps. thanks for leaving you feed back.
Aug 27, 2009 | RCA L42WD22 42 in. LCD Television
Instruction manual for RCA F27665
here is the link for the User Manual for the RCA F27655 Entertainment Series PIP
http://support.radioshack.com/support_video/54161.htm
Jan 13, 2009 | RCA F27665 27" TV
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
